PROP and 74HC595
Got what I hope is a simple question.· In any case, I have connected a prototype board to my PROP dev board.· The proto board has (2) inline 74HC595's to drive some transistors and relays.· Quite simple in fact.· Anyway, I am driving the 74HC595 chips with a simple SHIFTOUT function found here on the forums.· Question / Problem I am seeing/having is that the communication out of the PROP "looks" fine when analyzing it on my scope.· I am sending 16 continious bits, and the shift clock syncs up nicely to the bits being sent.· Yet, my 74HC595's sometimes have careless output, meaning not always syncing to what was sent.· This is ALWAYS the case on the 1st bit sent as well.· So if I send %1000000000000000 it should make Q8 on the 74HC595 go high, and never does, sometimes I see a high pin somewhere else, sometimes even on the second chip.
So my question I guess it, I am connecting the DATA, SHIFT, and LATCH thru a 18" long connection.· 8" from the protoboard, and 10" from the PROP dev board.· I am wondering what would be considered a "safe" distance, for this connection.· My assumption is that the connection is too long (+ the fact it is two cables connected together), and maybe the communication is stepping on bits, or something., or should I maybe make the first bit sent a little longer to compensate or something?
Any insight here would be greatly appreciated.
Shawn
Shawn
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
18" is bit far to run a high speed 3.3V logic signal without some help.
1) Use a twisted pair cable with the 2nd of each pair grounded. This provides a controlled impedance.
2) Use a pullup or pulldown resistor (maybe 10K) at the 74HC595 end of each signal to help absorb noise
3) Use a small series resistor at the Propeller end (maybe 100 Ohms) to help slow down signal edges and absorb noise
4) Make sure you've got enough capacitive filtering at the 74HC595 end for the power lines
It may depend on what "syncs up" means in reality; are you setting the data and asserting the clock at the same time or setting the data and then asserting the clock ? Likewise altering the data while de-asserting the clock ?
It could be a simple timing issue in which case add some delays between setting data, asserting clock, hold the clock, de-assert then alter data. I've had similar problems with parallel LCD's over long IDC cable which needed the timing stretched.
what is the timebase of the shiftoutfunction?
How many micro/milliseconds ?
Is this time longer than the minimum-spec in the datasheet ?
High-level on DIFFERENT pins let's me guess that the electrical connection might be bad
or even something is free flowing
If there appears a high on the second chip: are the two chips connected serially?
(Chip1 Pin Qh connected with Chip2 Pin SI)
If this is the case the bits of the first chip where shifted into the second chip with EVERY Clockcycle.
This means you have to send ALWAYS a 16bit pattern to make sure that the state of all 16 pins is defined like you wnat to have them
the clock-signal has to be switched after every databit. How do you manage this by a simple shiftout-function ?
and after shifting in all bits you have to switch the latch
What happens if you send an alternating pattern 10101010101...?
What happens if you send 16, 17, 18 bits?
to get an insight what MIGHT be the problem, you should answer these questions and post or attach your COMPELETE sourcecode
best regards
Stefan
Post Edited (StefanL38) : 5/20/2008 3:08:24 PM GMT
I am not using any decoupling at this point.· If need to do so, where is it exactly I should be putting decoupling capacitors?
Shawn
Best regards;
Peter
The setup time for DS to SH_CP is minimum of about 25 nS, so set the data bit add a delay >25nS then assert the clock output.
Leon
What I have working fine is the following code:
PUB Main ' only an example, not my exactly code here. HC595(DataOut, Clock, Comp_Out, 16) ' Send outs to both HC595's ' Wiring: 'pin 11 of both HC595's are Clock. 'pin 14 HC595 and 9 of this (first) HC, with pin 14 of the following HC595, are DataOut. 'pin 12 of both HC595's and R of 10KOhm to GND are Latch. 'pin 10 of both HC595 to +Vcc PUB HC595 (Dpin, Cpin, Value, Bits) {{ Shift data out, MSBFIRST }} outa[noparse][[/noparse]Dpin]:=0 ' Data pin = 0 dira[noparse][[/noparse]Dpin]~~ ' Set data as output outa[noparse][[/noparse]Cpin]:=0 dira[noparse][[/noparse]Cpin]~~ outa[noparse][[/noparse]Latch]:=0 ' dira[noparse][[/noparse]Latch]~~ ' REPEAT Bits outa[noparse][[/noparse]Dpin] := Value >> (bits-1) ' Set output Value := Value << 1 ' Shift value right !outa[noparse][[/noparse]Cpin] ' cycle clock !outa[noparse][[/noparse]Cpin] outa[noparse][[/noparse]Dpin]~ ' Set data to low !outa[noparse][[/noparse]Latch] ' !outa[noparse][[/noparse]Latch] 'But I have not tested this for long wires.
Regards.
Alberto.
PUB Out ( OutputLatchPinNo, OutputDataPinNo , OutputClockPinNo , OutputEnablePinNo , OutputNoOfBits , OutputByteValue )
DIRA [noparse][[/noparse]OutputLatchPinNo] ~~ '' SET the LATCH Pin to OUTPUT
OUTA [noparse][[/noparse]OutputLatchPinNo] := 0 '' TOGGLE the LATCH Pin OFF
DIRA [noparse][[/noparse]OutputDataPinNo] ~~ '' SET the DATA Pin to OUTPUT
OUTA [noparse][[/noparse]OutputDataPinNo] := 0 '' TOGGLE the DATA Pin OFF
DIRA [noparse][[/noparse]OutputClockPinNo] ~~ '' SET the CLOCK Pin to OUTPUT
OUTA [noparse][[/noparse]OutputClockPinNo] := 0 '' TOGGLE the CLOCK Pin OFF
WAITCNT(2500 + CNT)
myloop :=0
REPEAT OutputNoOfBits '' Start REPEAT LOOP for NoOfBits ie 8
·· myloop++
·· OUTA [noparse][[/noparse]OutputDataPinNo] := OutputByteValue >> ( OutputNoOfBits -1 ) '' SET the DATA pin to the first bit·
·· WAITCNT(1500 + CNT)
·· OutputByteValue := OutputByteValue << 1 '' SHIFT the BYTEVALUE to the Next Bit
·· OUTA [noparse][[/noparse]OutputClockPinNo] := 1 '' TOGGLE the CLOCK Pin ON
·· WAITCNT(5000 + CNT)
·· OUTA [noparse][[/noparse]OutputClockPinNo] := 0 '' TOGGLE the CLOCK Pin OFF
·· if myloop == 8
···· waitcnt(10000+cnt)
OUTA [noparse][[/noparse]OutputLatchPinNo] := 1 '' TOGGLE the LATCH Pin On
WAITCNT(1500 + CNT)
Pete
Post Edited (Propability) : 5/20/2008 5:14:12 PM GMT
first of all
if you use the POST REPLY Button you get menu Buttons like "CODE" "URL" etc.
you can use the button CODE to switch between normal text and SPIN-Code
(CODE) at the beginning
and (/CODE) at the end of the code
but with sharp edged brackets instead of "(" ")"
on thing that i can see is
for triggering the clock you use
the clock is triggert by a low-to-high -transition
so you would have to code vice versa
as probability mentioned
it depends on how you connected the Prop and the 74595
Here is my way. It does not use any pullup or pulldown-resistors at all
74HC595 'QA-QH 8Bit parallel Output QA─────────────┐ ┌──┐┌──┐ │ QB┤01└┘16├Vcc │ QC┤02 15├QA───┘ QD┤03 14├SI 'serial Data In QE┤04 13├G 'if low QA to QH-Outputs are enabled. If high QA to QH-Outputs are DISabled QF┤05 12├RCK 'low  high: ShiftRegister-Data is stored in Output-Latch-Register QG┤06 11├SCK 'low  high: triggers the ShiftRegister-Clock "shifts in" the bitvalue of SI QH┤07 10├SCLR 'if low ShiftRegister is cleared. If not connected to an Prop-IO connect to +Vcc GND┤08 09├Qh 'serial Data Output connect this Pin to SI of next 74xxx595 for cascading └──────┘ ┌ ←QA1─────────────┐ │ ┌──┐┌──┐ │ B ←QB1┤01└┘16├Vcc │ y ←QC1┤02 15├QA1──┘ t ←QD1┤03 14├SI─←────────────── ←connected to Propeller-IO-Pin "Prop_serial_out" e ←QE1┤04 13├G─→ Gnd 1 ←QF1┤05 12├RCK──────────┳──── connected to Propeller-IO-Pin "serial_out_RCK" │ ←QG1┤06 11├SCK──────────┼─┳── connected to Propeller-IO-Pin "serial_out_SCK" └ ←QH1┤07 10├SCLR→+Vcc │ │ GND┤08 09├Qh─→───────┐ │ │ └──────┘ │ │ │you posted only the modified PUB
NOT the whole program.
I cannot see how the PUB is called
maybe there is a fault too
a long time ago i made a program in SPIN for the 74595
i made separate PUB-Methods for everything that's a senseful unit.
By this way of coding you make sure if one PUB ist working you are REALLY sure
that an error is NOT inside this PUB because it has been tested separatly
There are only VERY few times where the error is still inside the tested PUBs
This is a quick copy and paste of the sourcecode
It compiles but i did not check it TODAY with the real hardware
in the past it was working
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 Delay = 1 Pin = 16 CON Prop_serial_out = 0'from Propeller to SI (serial in from shiftregister SN74HC595 serial_out_SCK = 1 serial_out_RCK = 2 serial_out_SCLR = 3 serial_out_G_QEnable = 4 Input = 0 Output = 1 Delay1 = 10 VAR long Delay_microS byte dummybyte PUB Main SO_Init_IO_74LS595 SO_ClearShiftR SO_ClearStoreR repeat SO_Write1Byte(3) SO_Write1Byte(6) SO_Write1Byte(12) SO_Write1Byte(24) SO_Write1Byte(16) SO_Write1Byte(48) SO_Write1Byte(64+128) SO_Write1Byte(128) wait_MS(500) PUB SO_Init_IO_74LS595 'set IO_direction DirA[noparse][[/noparse]Prop_serial_out] := OutPut DirA[noparse][[/noparse]serial_out_SCK ] := OutPut DirA[noparse][[/noparse]serial_out_RCK ] := OutPut DirA[noparse][[/noparse]serial_out_SCLR] := OutPut DirA[noparse][[/noparse]serial_out_G_QEnable] := OutPut 'Initialize Pin-state with value that does not change anything OutA[noparse][[/noparse]Prop_serial_out] := 0 OutA[noparse][[/noparse]serial_out_SCK ] := 1 ' OutA[noparse][[/noparse]serial_out_RCK ] := 1 OutA[noparse][[/noparse]serial_out_SCLR] := 1 OutA[noparse][[/noparse]serial_out_G_QEnable] := 0 PUB SO_Write1Byte(B) | BitFilter BitFilter := 128 repeat 8 if B & BitFilter OutA[noparse][[/noparse]Prop_serial_out] := 1 else OutA[noparse][[/noparse]Prop_serial_out] := 0 SO_Shift BitFilter >>= 1 'shift "1" right SO_Store PUB SO_ClearShiftR OutA[noparse][[/noparse]serial_out_SCLR] := 0 'state 0: ShiftRegister is clear wait_MS(Delay1) 'Wait for DelayMS cycles OutA[noparse][[/noparse]serial_out_SCLR] := 1 'change to state 1 after clearing PUB SO_ClearStoreR SO_ClearShiftR SO_Store PUB SO_Shift OutA[noparse][[/noparse]serial_out_SCK ] := 0 wait_MS(Delay1) 'Wait for DelayMS cycles OutA[noparse][[/noparse]serial_out_SCK ] := 1 'low-to-high triggers shifting wait_MS(Delay1) 'Wait for DelayMS cycles PUB SO_Store OutA[noparse][[/noparse]serial_out_RCK ] := 0 wait_MS(Delay1) 'Wait for DelayMS cycles OutA[noparse][[/noparse]serial_out_RCK ] := 1 'low-to-high triggers storing wait_MS(Delay1) 'Wait for DelayMS cycles PUB wait_MS(p_WaitTime_ms) waitcnt((clkfreq / 1000) * p_WaitTime_ms + cnt)Stefan
Post Edited (StefanL38) : 5/20/2008 5:26:16 PM GMT
How do the relays hook up, do they share the same return ground over 18 inches?
What are you using to strobe the shift registers other than clock and data?
If you are only using clock and data then outputs are tripped as you clock and with relays that means inductive spikes.
You need:
Proper grounds
Proper decoupling
*Peter*
As I look at it, I am more convinced this is not a software/sync issue, but if anyone see's something i do not, let me know.
As it stands now, the relays following the 74HC595 are non-inductive, in that the only thing flowing thru them is an alarm 12v 2.5ma signal.· No motor or anything which would "throw back".·
It seems the problem is ONLY with the 1st bit in series, all others function PERFECTLY.· No matter what bit i send as the first, the 74HC595 NEVER enables Output 8 as HIGH.· Only ODDITY is if I send all ("%1111111111111111") then it goes high (as do all the others).
SoI am wondering if it is something about NOT having a capacitor between VCC/VDD (decoupling).
Now to implement decoupling, I was told to place a capacitor between VCC and VDD.· 100nf.· Does this need to be on BOTH chips, or just the first in series...
Before I break out my little box horrors and stick one/two on, anyone see anything wrong with the image?
Shawn
Leon
where should i place the 10uf?· im powering this protoboard directly from the parallax prop dev board.
as for the "on chip" capacitors, can i just go pin to pin on the 74HC595 (meaning connect one end of cap to one and other end of cap to other pin) without removing any other connections?
As I said, its only the first bit (left most on the SCOPE image i posted, as bits move from right to left on the image), that does not go HIGH when sent. All other remaining when·I send 1 to the 74HC595 set the outputs to high.
Its just the screwiest thing.
myloop++
WAITCNT(1500 + CNT)
WAITCNT(5000 + CNT)
if myloop == 8
waitcnt(10000+cnt)
I see an 8 in there not a 16.
If this is not the code you are using then maybe post the code that does the 16 .
At the end of the sub their, the myloop ==8, is just create a little pause for me to see on the scope.
so, the repeat loops 16 times (or the number I send in when calling the method)
In this picture are the HC's, the code is what I wrote before in this thread, try that code, believe me ...it works, just is closer than your.
If you can try with short wires could be better, then you could larger them... & I always decouple all IC's with 0.1 uf (like in the picture...as near as possible the IC's).
Regards.
Alberto.
please reopen your mind to "the error CAN be EVERYWHERE"
The fact that all other bits are working perfectly does NOT mean
that the error HAS TO BE here or there
If you lost a key at night in the FOREST but search for the key on the STREET because there is more light
you will never find the key.
What happens to the leftest bit if you send 17 bits ?
What would be the worst thing that could happen if you post your COMPLETE code ?
Punishment-payments because you are not allowed by a contract?
does your scope-picture show the following bitpattern
did you check this carefully ?
Did you debug your software like this:
connect LEDs to EVERY of the 16 outputs to get a REALLY EASY overview about the logic state of each output
measuring voltages as too buggy
- insert codelines that printout the values of myloop and the state of databit and clock and latch via RS232 to a terminalsoftware
- toggle the latch after EVERY change of databit or clock
- waiting before and after EVERY toggle of the latch for a user-command to go on
By this way you can trace EVERY single detail of the shiftout-process
best regards
Stefan
Post Edited (StefanL38) : 5/21/2008 1:54:08 AM GMT
The code some of you are referring to was posted by me some time ago ( it was modified from the BS2 functions) , see my entry in this thread.
http://forums.parallax.com/forums/default.aspx?f=25&m=252598&g=252626#m252626
It works for me I have used it a lot with no problems, but please delete the "myloop++" and the "if my loop == 8" lines of your code , it is not needed as the REPEAT function handles the bit count.
Also make sure your xtal setting is set to..
CON
_CLKMODE =XTAL1 +PLL16X
_XINFREQ =5_000_000
refer to the PCB Layout PDF I posted there as well as that is my exact circuit I am still using today. note the de-coupling capacitors 0.1uf and the PULL-UP & PULL DOWN resistors 10K. The are also 1K current limiting resistors between the shift register and the prop as I am running the shift register at 5V so I can run leds!
test it with just LED's first before connecting the relays. ( MUST DO!)
Also, try short leads ( use one bread board) , I have used leads about 8" long and that works.
I have also used this with up to 4 shift registers with no problems!
I am not sure about "StefanL38" post about the low to hi transitions of the clock signal, but add some delay between the toggles.
OUTA [noparse][[/noparse]OutputClockPinNo] := 1 '' SET the CLOCK Pin ON
WAITCNT(1000 + CNT) '' add some delay , Try this
OUTA [noparse][[/noparse]OutputClockPinNo] := 0 '' SET the CLOCK Pin OFF
Again read my previous post!
Dave M
I was busy racing out the door before and missed the fact that you mentioned you had a latch signal as well. There is nothing wrong with the software as the scope shows it clocking out bits nicely (although very very slowly). Can you post the circuit because it has to be in the circuit or incorrect hookup if it's breadboarded.
*Peter*
I noticed too in an earlier post that mention was made of placing a decoupling cap between VCC and VDD. Well the decoupling cap should go between VCC and VSS or between VDD and VSS depending upon which terminology you employ. I prefer to say VCC for any +5V logic and VDD for any other logic voltage (higher or lower) as VCC refers to bipolar logic which usually runs at +5V.
*Peter*
I'm missing something ?
I used HC595 at 3.3Vcc to drive 16 optocouplers.....why to use it with +5 Vcc ?
NO buffers, only one resistor to GND, and it works fine in a machine....what's the problem ?
Regards.
Alberto.
I use switching regulators to +5V and a tiny SOT-23 pack 3.3V regulator for the final supply to the prop so naturally I would tie the heavier loads to the +5V rail. This also can include any visible light LEDs that the prop may drive as the forward voltage drop of any led is at least 1.6V and more. So I can drive my leds hard if I like yet not worry about the 3.3V supply.
Also, there is no rocket science involved in driving shift-registers but some thought has to be given to how they are connected up and what happens at reset when the I/O lines are floating (pull-down clock line), how long a line you are driving etc.
*Peter*
