Why telephone sets are immune to lightning strikes?
william chan
This question has been on my mind for some time now...
Why modems, routers and most equipments are prone to lightning strikes from the POTS lines but the classic telephone set itself is very resilient in surviving such strikes?
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
www.fd.com.my
www.mercedes.com.my
· On a similar note, when I was a kid, there was a nearby lightning strike and a shower of sparks came off the phone. It still worked OK afterward.
-phar
The older non-electronic phones were definately more rugged than electronic phones.· I have collected some antique phones from the early 1900's, and the basic technology remained the same until the introduction of touch-tone phones in the 60's.· I believe that the junction box on the outside of the house contains a fuse to handle lightning strikes.· This may only be in rural areas, or in areas where the phone lines are above ground.· When I was a kid, I remember the box cover being blown off a couple of times by lightning strike.· The cover landed about 50 to 100 feet from the house.· My parents always told us not to use the phone during a storm, but my brother was talking on the phone when one of the lightning strikes hit.· He ended flat on his back, but with no permanent injuries.
Dave
I've installed equipment at airports....your big city international airport doesn't usually qualify, but smaller airports tend to be on the edge of town where there is usually a very modest number of lines running to the airport....if the lightning (if = when) hits the line in a dense area, it's got more ways to disperse/diffuse, but in a rural area it'll tend to do some damage.
(we replaced many modems and the odd power supply because of this)
My boss used to live at the end of a long country road....his was the only phone on the line for a few km's. They had a rule that they'd wait for the 2nd ring before answering the phone! I was there when a lightning storm went through and the phone rang a number of times ( all single rings) and the lightning hit a fence post 50yards away (I hit the floor)....
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
Honestly, even a POTS phone from the 1960's that are bui;t like battleships·will not survive a direct lightning hit and still look pretty.· It's a matter of voltage induced·into the phone pair·from a nearby strike which would cause surge spike on the wire pair.· The thing is... compared to other sources and ground paths, the telephone· does not offer a really nice path to ground when compared to all the other·available paths... like the·ground wires·on the telephone poles or in above ground boxes.··Having a·better path NOT close to your NID means that the pair that runs to your phone or DSL gear·is spared death... IF it can survive the spike of the induced·surge voltage.
There's nothing like a new idea and a warm soldering iron.
pwillard, what type of car is that?
The CAR is my favorite toy.· It's a 2007 Saturn SKY I've had about a year and a half.· Also known as the OPEL GT in europe.· Loads of fun to drive on the· curvy·North Ga Mountain roads·near my home.
In truth, in the early days of telephone, people were far more aware of lightning playing a role in electricity. After all, Benj. Franklin was a major contributor to the field with recognizing that electricity had polarity. He may have gotten lightning rods popularized to.
So, the phone companies had to deal robustly with the perception that any telephone might be potentially lethal. The service had hefty protection and a lot of redundant protection. These days, we just let the chips fry.
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
Whenever I get back to the states, I plan to pick up an old heavy touch tone. Weight is another problem. Whenever I pick up the handset, the rest of the phone goes on the floor.
Traditionally, the telephone lines had spark arrestors where they entered the building. Some of these were simply pairs of sharpened points that allowed the lightning to jump to ground. But I don''t see anything like that in Taiwan -- not sure what they do to arrest lightning.
Many businesses seem to run without one.
All the public telephone boxes were removed throughout Finland some years ago.
The longer answer is that lightning has to follow a path through a device to ground in order to effect destruction, and as jmalaysia suggested it's just not too likely that the path of least resistance will go up the tip wire, through your phone, and back down the ring wire when it could just arc over at the box outside your house. And older phones contain only passive components, which are less likely to be destroyed by a short burst of energy. I have heard of newer phones, especially the more complex ones that need AC power, getting destroyed by lightning.
Then they stopped connecting that yellow wire to ground and ran just the green and red wire into the house. I think they (Bell Labs) figured out that it was best to NOT provide a path to ground inside the house!
FYI - The green and red wires are called "Tip" and "Ring". This is from the days when they had telephone operators who connected your call by inserting the following into the correct connection hole...
"Hoover required". ??? In his role as telephone gauleiter or what? Get real.
Cellphones suck because they only do half-duplex, you can't tell the other party to... "stop already"... till they take a breath.
http://www.telephonecollectors.info/index.php?option=com_docman&task=doc_download&gid=2093&Itemid=2
I had an engineering professor who told the story of how he was hired by Bell Labs to design a spring clip to hold an inductor in place on the PCB of a telephone. (His account of the design process was absolutely fascinating!) If Bell would hire a PhD just to design a spring clip, imagine the scrutiny everything else received!
No one today could afford to take that kind of approach.
