Test Proto Board with 1xLED + simple spin code
Cluso99
By adding just one Ultra Bright LED and this simple spin code you can test that the PCB is working.
If you are careful, you do not even have to solder the LED.
Once you know your board is working follow the excellent tutorials in the Propeller Manual Chapter 3.
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card? - PropDOS
Need a part? Got spare electronics? - The Electronics Exchange
