Two versions of IDE simultaneously (working)
Does anyone know if it is possible to run 2 versions of the IDE (in Vista) simultaneously?
I tried the obvious, but the IDE only allows one instance.
(see my post 13 May 2008 below for·full details·of how to get it running)
Post Edited (Cluso99) : 5/14/2008 4:44:16 AM GMT
Timothy D. Swieter
www.brilldea.com·- check out the uOLED-IOC, an I/O expansion for the uOLED-96-PROP
www.tdswieter.com
One little spark of imagination is all it takes for an idea to explode
I would like to be able to download code into both boards.
One can monitor the other, etc.
I have jumper links for each sideto in the A & B (serial) sides independently to...
1. Select +3V3 or +5V I/O
2. Disable DTR signal (prevents Hyperterminal from resetting the propeller)
Two additional pin headers for each TXD & RXD pairs. This allows me to...
1. Test the FT2232C in loopback
2. Test the FT2232C from channel A to B and visa versa
3. Snoop either the TXD or RXD on one channel to the RXD on the other channel.
This is achieved by a 2 wire header cable.
I have 2 instances of the Propeller IDE running under Vista. (Enabled from the Propeller IDE Edit/Preferences/Files & Folders/ uncheck Associated files launch into·single editor - thanks to Chuck)
My Proto Board has a single LED for testing purposes (see my post "Test Proto Board with 1xLED + simple spin code").
Enjoy
Now for some serious programming......
