Driving multiple buzzers
I see buzzers running straight off the output pins all the time, but in a case where there are 3 buzzers on one pin is this a potential problem for the Prop?
I haven't ordered these yet to test, but to run three off one pin in parallel [noparse][[/noparse]must be parallel], would a transistor be best to drive them?
It shows 4.0 min operating voltage below on the data sheet for a buzzer I found off digikey.
Part No: CCG-1206
Magnetic Buzzer
Rated voltage 5 Vo-p
Operating voltage 4.0 - 8.0 Vo-p
Mean current 50 mA max. Applying rated voltage, 2400 Hz square wave, ½ duty
Coil resistance 40 ± 6 Ω
Rated frequency 2,400 Hz
The data sheet shows their method of testing using a transistor and 2.5v square wave input.
Part No: CCG-1206
Magnetic Buzzer
I just added a LM386 amp to the Prop, that way I have more than enough gain if needed, and not have to worry about damaging the Prop.
