F3F RC slope racing timer — Parallax Forums
rpleymrpleym Posts: 2
edited 2008-04-30 04:11 in BASIC Stamp
Hello
I'm planning a project to make a timing system for F3F competition. This is a RC glider slope racing competition, where you basically set up a course which is 100 m long, and fly back and forth in this course 10 times as fast as you can. In each end of the course there is a referee who pushes a button when the plane passes him, which sounds a buzzer behind the pilot so that he knows when to turn.
What I want to make is a timer that starts when the first button is pushed (referee 1), then counts laps and stops when referee 1 is passed again·at the end of·the 10'th lap.·I also need a simple LCD display of course, to display the results.
I was thinking I could do this with a BS1 with an external timer chip, but I'm not sure. Any tips would be greatly appreciated [noparse]:)[/noparse]
Which timer chip should I use? I need about 1/10·sec resolution I think
- Richard Pleym
  • rpleymrpleym Posts: 2
    edited 2008-04-29 06:23
    I'm having trouble finding a RTC chip that can give 1/10 and 1/100 sec which isn't surface mounted, any hints?
    You can do it just using the BS1 and calibrated timing loops, without any external RTC.
    Your code will have several nested for-next loops (maybe with short pauses) that count the seconds and minutes. You'll experimentally determine the loop size by comparing with a real stopwatch. Depending on the total timing interval, you could calibrate it within reasonable limits, perhaps 1/10 second. You'll have if-then statements monitoring the pushbutton inside your loops. Write your code so that your loop execution speed doesn't change if & when·the button is pressed, and wait to output data to a serial LCD until your timing is finished.
