Storing pulseCount Data
Hello ... How do I store the value of pulseCounts used to drive the servos at a certain period of time·then recall this value at another time. For example, the following code is used in my program:
FOR pulseCount = 0 TO 2310··· ' PulseCount to Drive·396 Inches forward········
····PULSOUT LeftServo, 850
··· PULSOUT RightServo, 650
··· PAUSE 20
NEXT
if an object is detected,·then my Bot will maneuver around it using the following simple code:
FOR pulseCount = 0 TO 20························ ' 90 Degrees Right Turn
··· PULSOUT LeftServo, 850
··· PULSOUT RightServo, 850
··· PAUSE 20
· NEXT
· FOR pulseCount = 0 TO 70······················ ' 12 inches
··· PAUSE 20
· NEXT
· FOR pulseCount = 0 TO 20····················· ' 90 Degrees Left Turn
··· PULSOUT LeftServo, 650
··· PAUSE 20
· NEXT
· FOR pulseCount = 0 TO 140··················· ' Avoid Object
··· PAUSE 20
· NEXT
· FOR pulseCount = 0 TO 20···················· ' 90 Degrees Left Turn
··· PAUSE 20
· NEXT
· FOR pulseCount = 0 TO 70···················· ' 12 Inches
··· PAUSE 20
· NEXT
· FOR pulseCount = 0 TO 15··················· ' 90 Degrees Right Turn
··· PULSOUT rightServo, 850
··· PAUSE 20
· NEXT
The problem is how can i recall the pulseCount value·when an object is detected and use it after maneuvering to calculate for the remaining pulses needed to drive the servos for the remaining distance??
Let us say that an object is detected at 200 Inches, I must obtain the pulseCount at this time, and·after manuvering,·i must recall the value to use it in the following logic:
pulseCount·=pulseCount + 140·· ( This is the covered Distance)
reamining distance is 2310 - pulseCount
Thank you
··· PAUSE 20
NEXT
··· PAUSE 20
· NEXT
··· PAUSE 20
· NEXT
··· PAUSE 20
· NEXT
··· PAUSE 20
· NEXT
··· PAUSE 20
· NEXT
··· PAUSE 20
· NEXT
··· PAUSE 20
· NEXT
Thank you
FOR pulseCount = 0 TO 2310 ' PulseCount to Drive 396 Inches forward
IF Objectavoided then pulsecount=pulsecount+140
PAUSE 20
NEXT
Post Edited (jmalaysia) : 4/6/2008 1:44:25 AM GMT
(pulseCount when object is detected + 140) = Distance Covered
Original value for pulseCount which is 2310 - Distnace covered = remaining pulses needed.
I am not sure hot to store the pulseCount value when the object is detected and recall it later after manuvering? I was trying to use the Read command but it did not work!!
StartFresh: InitialValue = 0 DoAMove: FOR pulseCount = InitialValue TO 2310 IF ObjectFound THEN GOSUB GoAroundIt InitialValue = pulseCount + AdjustmentForAvoidance GOTO DoAMove ENDIF PULSOUT LeftServo, 850 PULSOUT RightServo, 650 PAUSE 20 NEXTOops, see change above
Post Edited (Mike Green) : 4/6/2008 4:31:35 AM GMT
I need some explanation for what my Bot is doing; I am using the following simple code:
' {$STAMP BS2}
' {$PBASIC 2.5}
pulseCount VAR Byte ' Used For Measuring Turns
RightServo PIN 12 ' Right Servo is connected to pin 12
LeftServo PIN 13 ' Left Servo is connected to pin 13
task VAR Nib ' Current Task Being Performed
InitialValue VAR Nib ' Pulse value for task0,2,4
Piezo PIN 4 ' Piezo Speaker is connected to pin 4
GOSUB Drive
END
Drive:
InitialValue = 0
FOR pulseCount = InitialValue TO 272 *** This is where my problem is .... Please read below
PULSOUT RightServo, 675
PAUSE 20
NEXT
RETURN
when i set my value to 68, my bot will go forward for 12 Inches ... But when i set my vlaue for 272 to have my Bot drive forward for 48 Inches, It just keep going forward for ever. I am not sure why it is doing that, can some one please help. Thank you
By the way, you have 3 identical messages. Please delete the extra ones (use the X in the upper right corner of the message window).
pulseCount VAR Word ' Used For Measuring Turns
Task VAR Nib ' Current Task Being Performed
pulse VAR Byte ' Pulse value for task0,2,4
InitialValue VAR Word ' Pulse value for task0,2,4
PAUSE 2000
FREQOUT Piezo, 100, 3000 ' Buzzer Initiate Indicating
ON Task GOSUB Task0, Task1, Task2, Task3, Task4
END
Task0:
InitialValue = 0
PULSOUT LeftServo, 850 ' Forward for 396 Inches
PAUSE 20
NEXT
RETURN
Task1:
FOR pulseCount = 0 TO 20 ' 90 Degrees Left Turn
PAUSE 20
NEXT
RETURN
Task2:
InitialValue = 0
FOR pulseCount = InitialValue TO pulse
PULSOUT LeftServo, 850 ' Forward for 408 Inches
PAUSE 20
NEXT
RETURN
Task3:
PAUSE 20
NEXT
RETURN
Task4:
InitialValue = 0
PULSOUT LeftServo, 850 ' Forward for 60 Inches
PAUSE 20
NEXT
RETURN
MAIN:
On Task Gosub ...
Task = Task + 1
·IF Task > 5 THEN
· Task = 0
·ENDIF
GOTO MAIN
