Distance between Long/Lat on BS2
Hello All,
I’m using a BS2 microcontroller with the Parallax GPS Receiver module to get longitude/latitude data into my stamp. I have two sets of coordinates that I want to calculate the distance between. Is this possible, and how is it best to go about it?
I’ve programmed forever, but never on a system that couldn’t do floating-point arithmetic! My approach was to use the haversine formula, but I can’t figure out how with the BS2’s weird trig functions and lack of fractional number support. I’m including some (non-working) code I was fiddling with just so you can see the direction I was thinking. The commented out code is a working Javascript function I was trying to emulate.
But really, I have no idea what I’m doing. If anyone could give me some guidance on how to calculate the distance between two sets of longitude/latitude coordinates, or tell me that it absolutely cannot be done on a BS2, I’d really appreciate it!
Thanks in advance,
Matthew
Thanks in advance,
Matthew
' {$STAMP BS2}
' {$PBASIC 2.5}
Lat1Deg VAR Byte
Lat1Min VAR Word
Lon1Deg VAR Byte
Lon1Min VAR Word
Lat2Deg VAR Byte
Lat2Min VAR Word
Lon2Deg VAR Byte
Lon2Min VAR Word
R CON 6371
dLat VAR Word
dLon VAR Word
a VAR Word
c VAR Word
d VAR Word
' BEGIN
Lat1Deg = 38
Lat1Min = 0353
Lon1Deg = -78
Lon1Min = 5165
Lat2Deg = 38
Lat2Min = 0346
Lon2Deg = -78
Lon2Min = 5159
dLat = (Lat2Min - Lat1Min) * (128 / 180)
dLon = (Lon2Min - Lon1Min) * (128 / 180)
Lat1Min = Lat1Min * (128 / 180)
Lat2Min = Lat2Min * (128 / 180)
Lon1Min = Lon1Min * (128 / 180)
Lon2Min = Lon2Min * (128 / 180)
'var R = 6371; // km
'var dLat = (lat2-lat1).toRad();
'var dLon = (lon2-lon1).toRad();
'var a = Math.SIN(dLat/2) * Math.SIN(dLat/2) +
' Math.COS(lat1.toRad()) * Math.COS(lat2.toRad()) *
' Math.SIN(dLon/2) * Math.SIN(dLon/2);
'var c = 2 * Math.atan2(Math.sqrt(a), Math.sqrt(1-a));
'var d = R * c;
a = SIN(dLat/2) * SIN(dLat/2)
a = a + (COS(Lat1Min) * COS(Lat2Min) * SIN(dLon/2) * SIN(dLon/2))
c = 2 * (SQR(a) ATN SQR(1-a))
d = R * c
DEBUG SDEC d
http://www.parallax.com/tabid/617/List/0/CategoryID/82/Level/a/SortField/0/Default.aspx
are asking about:
www.micromegacorp.com/downloads/documentation/AN039-GC%20Distance.pdf
and
www.micromegacorp.com/downloads/software/AN39-GC%20Distance.zip
phil
- Stephen
A javascript implementation is as follows:
var R = 6371; // km var dLat = (lat2-lat1).toRad(); var dLon = (lon2-lon1).toRad(); var a = Math.sin(dLat/2) * Math.sin(dLat/2) + Math.cos(lat1.toRad()) * Math.cos(lat2.toRad()) * Math.sin(dLon/2) * Math.sin(dLon/2); var c = 2 * Math.atan2(Math.sqrt(a), Math.sqrt(1-a)); var d = R * c;Where lat/lon are in decimal degrees (obviously not possible on the BS2).
More info on this formula can be found http://www.movable-type.co.uk/scripts/latlong.html
Thanks so much for the assistance!
Have you looked at the ATN (Arctangent) or HYP (Hypotenuse) functions built into the BS2?
There is also SIN (Sine of an Angle), COS (Cosine of Angle), and SQR (Square Root)
The HYP could be used in determining distance... To get·more resolution you might need to apply the function in a long hand sort of way by looking at your Delta X and Delta Y in decade increments.
The ATN combined with SIN, COS, and SQR could be applied to your JavaScript example, but I think the long-hand HYP method might provide better resolution.
Beau Schwabe
IC Layout Engineer
They allow you to get the results of 32 bit multiplications and allow multiplication by fractional amounts.
I'd use only the minutes and fractional minutes, ignoring the degrees in your computations to make the math a bit easier. You'd have to know what the distance was locally for a fraction of longitude and latitude (use google maps)
If your robot path does cross a degree, you could just shift all the coordinates a half degree and proceed with the math, then shift back after the computations.
Or, you can change to brads and use the BS2's trig functions.
A good article was written by John Overstrom about the problem in the April 2008 issue of SERVO, including the following code--
www.servomagazine.com/media-files/866/GPS_Guided_Car.zip
That should get you started.
Pay attention to a couple of "gotchas" the author deals with, including the "zero crossing" steering issue.
Tracy Allen
www.emesystems.com
And lat, dlat and dlong are the differences in radians, although you will have to play with the scaling in order to use the Stamp ** operator and to avoid integer overflow. R*cos(lat) will be a constant. I think that is right, but check me on it. Then apply Pythagoras. Here is a link to extend the accuracy of the SQR operator using the high school algorithm.
Tracy Allen
www.emesystems.com
All of the information you're seeking can be found in the PBASIC Reference Manual which can be downloaded for FREE from the Parallax web site. The Parallax web site is here:
Once you reach the web site, go to the Downloads Section. You will find the Reference Manual there along with other free downloads all of which relate to the PBASIC Stamp.
Bruce Bates
Involvement and committment can be best understood by looking at a plate of ham and eggs. The chicken was involved, but the pig was committed. ANON
Post Edited (Bruce Bates) : 4/28/2008 1:37:08 PM GMT
However, note that the run-time math does not contain any trig.
-- The R*cos(lat) is a constant, at your average latitude. (we will assume you are not circling close to the north or south pole!) Forget about R, which will rolled into the scaling constant at the end. Find cos(lat) on your calculator, a number between zero and 1, and multiply that times 65536. Call that number B, B= 65536 * cos(lat).
-- The first calculation on the Stamp will be to subtract the two latitudes and the two longitudes to get the difference in fractional minutes. Will your distances be more than one minute (about 1800 meters, by quick calculation)? It might require a simple borrow from minutes and maybe even from degrees (where the borrow adds 60, not 100 minutes to the borrowee), but it is simple math rules. Both of those dlat and dlong will be Words in fractional minutes.
-- Now have the Stamp multiply the difference dlong by the factor B using the ** operator:
dlong = dlong ** B.
That accounts for the intrinsic scaling factor cos(lat).
-- At this point, The Stamp could do another scaling tto put dlat and dlong directly in units of meters. That would involve another ** operator to account for R and a local fudge factor and a unit conversion constant. You don't have to sort through all those constants in theory. Just take two points in your area, and you know the actual distance between them (from a map or from Google), and that lets you figure the scaling constant. How many meters do you expect to move?
-- Now comes the tricky part. It may be that the sum of the squares, dlong^2 + dlat^2 would overflow one word. That happens if the individual distances are combinations like (256,0) or (182,182). This is a situation where I might be inclined to go for double precision to have the Stamp figure the sum of the squares into 32 bits. Then take the square root of that, which can be done without too much trouble.
Tracy Allen
www.emesystems.com
Post Edited (Tracy Allen) : 4/28/2008 4:40:27 PM GMT
