Ads592 — Parallax Forums
Ads592
bambinobambino Posts: 789
edited 2008-04-28 00:34 in Propeller 1
Would this circuit work on the prop. The 220 ohm I think would protect the pin, but would it make an accurate rcTime to temperature conversion?
    edited 2008-04-27 17:04
    I used that circuit on the Stamp for the Applied Sensors series. It is on the edge. The AD592 specs suggest at least 4 volts across the chip to support correct linear operation, but at the 1.6 volt Prop threshold, that leaves only 3.4 volts across the AD592. It would be better if the top of the AD592 could come from a higher voltage. I found that it typically did still work, though, with 5 volts into the Stamp's 1.4 volt threshold. The result depends on the tolerances and drifts of all the components, including the drift and noise of the prop threshold. It is important to avoid ground loops. Don't expect more than a couple of degrees accuracy.
    You could also have the AD592 feed a sigma-delta converter, which would I think be considerably more accurate.
    Tracy Allen
    www.emesystems.com
  • bambinobambino Posts: 789
    edited 2008-04-27 20:39
    Thank you Tracy for your insight!
    I beleive I'll take your advice and go with a convertor.
    edited 2008-04-27 23:44
    Tracy,
    I just found this[noparse]:http:[/noparse]
    //www.national.com/mpf/LM/LM19.html
    Would this not be the 3.3v compatable version of the 592?
    Well, the LM19 is a voltage output device, so it would be compatible with a voltage input ADC. Another option if you want a current output that could feed a Prop sigma delta or RCtime would be the venerable LM334. It can operate down to less than 1.5 V of overhead. Here are ideas for constructing an LM334 probe.
    Tracy Allen
    www.emesystems.com
