Please explain Capacitor coupling
Since the output of a microcontroller is a 0 to 5 positive volt swing, how is it that a capacitor·can couple the output to another device, such as the LM386 audio amp? It works, but I don't understand how without a negative and positive voltage swing about ground. I thought I understood capacitors, I guess I don't. Will someone please explain?
Richard
Richard
Richard
In the case of coupling to a high impedance at the output, think of it as a closed tube at the outlet with a pressure sensor, and the pressure on the inlet side is transferred directly to the outlet through the membrane, and the membrane doesn't even have to move or store any energy. In the case of coupling into a short circuit, think of the output ending in a big lake so the pressure is there constant. Fluid is transfered from inlet to outlet until the difference between the inlet and outlet pressure is exactly counterbalanced by the stretch in the diaphragm. That means in analogy that the capacitor is charged up to the difference voltage. Resistance in series with the capacitor on the input or output is like a length of a smaller diameter tube with fricative (dissipative) forces.
The LM386 audio amp is pretty close to presenting a high impedance, so it is like that pressure measuring device. But you can't make the capacitor too small, because the LM386 does have a finite input impedance, and too low a capacitance value will couple through a low, distorted signal.
With a high frequency sinusoidal input, relative to 1/R*C, the stretch in the diaphragm (voltage across the capacitor) will be greatest when fluid flow (current) passes through zero. Then the voltage and the current waveforms are 90 degrees out of phase.
Tracy Allen
www.emesystems.com
