Creating Gerbers from Eagle
william chan
Hi,
Anybody knows the best and correct steps to create Gerber files from an Eagle BRD file?
How many files should the final output be?
Why are there so many types and versions of Gerber files?
Which type should I create?
How to check that your Gerber files are correctly created?
Thanks.
www.fd.com.my
www.mercedes.com.my
Thanks.
www.fd.com.my
www.mercedes.com.my
I always use the RS-274-X format. Every PCB supplier can handle it (it includes the photo-plot apertures, unlike RS-274-D).
There are several Gerber viewers available, I use GC-Prevue. A free version is available.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
Post Edited (Leon) : 4/23/2008 7:00:05 AM GMT
I sent some Geber files to China in order to get my Canbus boards made. The jobber then told me what I was lacking and I had to contact Eagle to determine what they wanted and how to create it.
It isn't really a big deal, but does cause production delays the first time around. It is just that there are several version of Geber and the fabricator may have old software. Eagle will generate all the proper files, but in some cases the extension of the file name has to be changed.
So, the general process is:
1. get quotes for boards and ask them which version of Gerber and what files they want.
2. attempt to generate all of these yourself.
3. review the documentation and contact Eagle for support if you cannot get everything done yourself.
4. send files to the vendor for verification prior to production
5. confirm the images that are returned to you are exactly what you want as you are responsible for all errors and omissions.
Some of the files are dependent of specific machinery. The drilling files are one example and you may have to adjust from inches to metric sizes. Also, you may have specified drill sizes that are not available. These need to be swapped out with what the fabricator can provide.
In my case, the boards came back electrically perfect, but my printed overlays were a bit messed up because I didn't carefully review them. Larger boards obviously are harder to check, so go slow.
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
I use Eagle CAD and have my boards produced by PCBCart, I also use GC Prevue to check the gerbers.
There is a short tutorial on how to produce the gerbers here it is an easy process to follow...
www.interq.or.jp/japan/se-inoue/e_eagle44.htm
It worked for me!!
I have to agree with Kramer, always get a quote first.
Coley
PropGFX Forums - The home of the Hybrid Development System and PropGFX Lite
www.fd.com.my
www.mercedes.com.my
I haven't found any company that comes close to competing on price compared·to PCBCart.
Chris I.
Leon
Besides the gerbers, you may need to look into the design rules that a manufacturer has. Different PCB manufacturers have different size tracks, drills, spacing, etc. Setup your design rules so they are right so you don’t get delayed by having to redo your file.
I use PCBCart. Great service and prices! I have produced several orders with them and I have corresponded with them on several topics via e-mail and chat. I vouch for their good services and prices. Yes, I also second that PCBCart can take Eagle files, but I don't use that service. I prefer to make the gerber files myself and double check them. I have used various viewers. My favorite at the moment is http://www.circuitpeople.com/ because it is easy and painless and provides great images of your board for checking them.
Timothy D. Swieter
www.brilldea.com·- check out the uOLED-IOC, an I/O expansion for the uOLED-96-PROP
www.tdswieter.com
One little spark of imagination is all it takes for an idea to explode
