Quick questions about Hydra-Net port..
RobotWorkshop
I've got everything wired up and working perfect on my Hydra clone with the exception of one last thing. The TX and the RX lines to the RJ-11 jack. Since I don't have access to a real Hydra board I just want to confirm those connections. If I look at the end of the jack where the cable plugs in with the wires at the top and the catch on the bottom what is the orientation of the RX and TX? Would the TX be on the right or left (of the center two pins)? Once I confirm that I can wire them up.
Robert
Robert
Looking into the socket it is GND - RX - TX - GND (TX -> R43, RX -> R23).
