Using trigonometric funtions with SX Chips. ( Help)
Hi,
Only to know if I can use trigonometric funtions
and logarithm funtions with SX chips.
Thanks, Joe
Thanks, Joe
The problem I have is that Basic compiler
is very similar to use a Basic Stamp (easy) and
the alternative of using a Propeller could
be usefull but I need to understand Spin or assembler.
for this reason I would like to use SX.
Do you know if adding the math coprocesor to the SX is a
good alternative ? ( better than a propeller)
thanks, Joe
Bean.
Did you know that 111,111,111 multiplied by 111,111,111 equals 12345678987654321 ?
www.iElectronicDesigns.com
I found a microcontroller called BasicX-24
and I would like to use Parallax products instead of
BasicX-24.
The BasicX-24 has a lot of math.
and am trying to have the same
( or similar) math with Parallax products.
( But I dont want to use the propeller because
I want to continue with Basic instead of Spin.
If you know how, here is the link:
http://www.basicx.com/Products/BX-24/bx24instset.htm
Thanks, Joe
PS: I don't want to move from Parallax becuase you
have a very good support, thanks.
I read the Propeller manual and It is difficult
to understand.
I thought that Spin was like PBasic but isn't.
Why Parallax doesn't add Pbasic to the Propeller?
( Or something similar to the PBasic)
I have waist several days learning Pbasic and
I will not waist several days again learning Spin.
I will need to buy the BX-24 this time because Basic Stamps
don't have enough math., SX does not has enough math too
and Propeller is too difficult to understand.
Any way thanks for the support .
Joe
Take a look Bean's comments on the Compass module which requires the use of some trig functions
http://forums.parallax.com/forums/default.aspx?f=7&m=159976&g=161596#m161596
John J. Couture
San Diego Miramar College
