couldnt find the bug , interessant — Parallax Forums
davrandavran Posts: 12
edited 2008-04-16 23:27 in Propeller 1
i wanted to make a simple frequency generator. but at the first draft my software failed..
the code below fails between the lines 30-34. the loop causes the screen lost and pin0 gives a variable frequency.
does the code have any error or am i doing sth wrong?
thanks for the answers.
here is the full source :
Post Edited (davran elektronik) : 4/16/2008 8:23:07 PM GMT
  • davrandavran Posts: 12
    edited 2008-04-16 20:45
    i deleted the byte variable d after that the code worked. now i must find sth else instead of d .
    but what is wrong with "d"
    "Give a lie twenty-four hours start, and it will take a hundred years to overtake it.
    " (C.F. Dixon-Johnson, British author of the 1916 book, "The Armenians," appalled over the deceitful practices of his book's subject.)
    www.tallarmeniantale.com/
    Post Edited (davran) : 4/16/2008 8:59:01 PM GMT
    168 x 80 - 916B
    160 x 85 - 995B
    166 x 72 - 845B
    edited 2008-04-16 21:33
    Your problem is that array subscripts run from 0 to n-1 where the array is declared to be of size n.
    Your loop assumes that the subscripts run from 1 to n, so the byte after p gets altered when you reference p[noparse][[/noparse] 10 ].
    edited 2008-04-16 21:46
    hello davran,
    in your first version the loop starts with repeat (d-1) with d= 1 it means repeat 0
    and this might be endlessly doing p[noparse][[/noparse]c] *= 10
    what the hell should the second version do with repeat (d-1-d+2) ?????
    third version starts with repeat 1
    best regards
    Stefan
  • rokickirokicki Posts: 1,000
    Just to make a minor correction:
    in C,
    int a[noparse][[/noparse]10]
    declares space for *10* elements, indexed 0..9.
    I couldn't let the "11 elements" comment confuse anyone and lead to more buffer overruns or whatnot.
