Power supply question
I would like to know if AMPS double in connected regulators.
For example:
I have a very healthy 12v DC power supply that can deliver up to 20 amps.
My intention is to put a voltage divider to create two 6 volt rails.· Each 6 volt rail will power a 5 volt and 3 volt voltage regulator.· That's a total of 4 regulators in all.· Tie in the grounds into one common ground, some heat sync compound and a good heat sync tied across all four regulators.
If I'm that close to the max safe output of·one regulator, should I:
be content with four seperate power busses?
If I tie the 3 volt output from each 3 volt regulator into one 3 volt rail:
Will the·total available amps·on the 3 volt rail be the sum of the regulator's max output?
Will the amp draw be spread out across the regulators?
Propeller + Hardware - extra bits for the bit bucket =· 1 Coffeeless KaosKidd
For example:
P = V x I
Power (watts) = Voltage by Current.
So if you halve the voltage you have to double the current = yes. Obviously if you loose loads on the conversion it doesn't quite work that simply.
no - unless you spread the load yourself.· You generally shouldn't have two regulators feeding the same load - I forget exactly why - I think they
oscillate or something.· You can purchase 5amp, etc, regs.
J
Post Edited (Javalin) : 4/15/2008 9:43:48 AM GMT
Yes if you trasform power (but the efficiency is never 100%, near 90% is more normal).
No if you do not transform power. i.e. Using a series regulator means that the difference voltage between input and output times the current is lost power in the regulator.
This is basic stuff, has nothing to do with the propeller. Please read the datasheets for a common series regulator like the 7805 and for a switching regulator like the TL494. Plus, at national semiconductor's site (www.national.com) for these and other regulators (like LM317) there are application notes that describe how regulators work, the different types and so on. Please download them and read them, and try the circuits so you can see and experiment with those circuits. The best way to learn.
Edit: Ops, javalin I did not see you post.. I was just writing!, is ok.
Post Edited (Ale) : 4/15/2008 9:51:44 AM GMT
If you do this than you shouldn't need the voltage divider.
Edit: Thinking about this some more. You can connect regulators in parallel but you have to put a small resistor on the output of them so that you don't get into problems with the different voltages.
Post Edited (stevenmess2004) : 4/15/2008 11:58:13 AM GMT
The issue is I'm drawing enough through one regulator that it's very warm (not hot)...
I heat synced it, but in thinking about it, and reading everyone's replies...
that a larger regulator or a new dedicated power supply will solve the issue..
Thanks every one.
Warm not hot ( in fact not "ouch" hot ) is in my experience acceptable. I have a 12V-6V linear regulator for a very old digital camera ( ~1A draw ) with a largish heatsink which doubles as a hand warmer.
It's not so much how much current your source can deliver but how much is used and how much the regulator has to dissipate.
If you have a data sheet I can show you the calcs you need to do to figure out the heatsink/voltage/current you can do with the regulator you've got.
The more I know, the more I know I don't know.· Is this what they call Wisdom?
