Variable Pin # in PULSOUT
I feel like I am missing something obvious.· I want to put the Pulsout command into a subroutine and be able to supply it with a variable pin number.
John J. Couture
San Diego Miramar College
John J. Couture
Main: SERVO 1,150 SERVO 0,100 goto main ' ----------------------------------------------------------- ' Subroutine Code ' ----------------------------------------------------------- SERVO: ' USE: SERVO servo#, pulse duration IF __PARAM1 = 1 THEN PULSOUT Servo_Grip, __PARAM2 ELSE PULSOUT Servo_Base, __PARAM2 ENDIF ENDSUB▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
-Paul
Post Edited (Velocit
' Use: PULSE_OUT pin, timing ' -- pin is 0 to 15 (RB.0 to RC.7) ' -- timing is in microseconds SUB PULSE_OUT IF __PARAMCNT = 2 THEN tmpB1 = __PARAM1 tmpW1 = __PARAM2 ELSE tmpB1 = __PARAM1 tmpW1 = __WPARAM23 ENDIF tmpW2 = 1 << tmpB1 ' create pin mask RBC = RBC XOR tmpW2 ' toggle the pin PAUSEUS tmpW1 ' wait RBC = RBC XOR tmpW2 ' toggle back ENDSUB▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
John J. Couture
Note that my version (above) does not make the pin an output; you should make any pin that will be pulsed an output and it the non-pulse state before using the routine.
Another great thing about SX/B is that you can mix assembly into BASIC, and use interrupts. I've attached reasonably-simple program that has an eight-channel virtual servo controller connected to RB.0 to RB.7. EFX-TEK customers do a lot of servo animations so this framework makes things easy on them; all they have to do is tell a servo where to be in the foreground (via the pos array) and the ISR takes care of the rest -- for up to eight servos.
Post Edited (JonnyMac) : 4/12/2008 9:41:46 PM GMT
