Serial in a USB world and what options do I have?
I'm guessing this has been beat to death, I did a search for this but didn't quite find what I what I need to know. I just got a serial boe bot (the price was right)
and have an all USB computer. I know I can buy the adapter from Parallax, but was wondering if a USB to serial cable from the local store will
work, or if a serial card in my computer will also solve the problem. In other words, is the serial to USB converter that Parallax has the only way to get my boe bot
connected to my computer? And if not the only way, is there a 'best' way?
Prune Free.
Prune Free.
If you want to try a USB-to-serial cable other than Parallax's then determine beforehand·that it can do all of the hand-shaking·because not all of them·do so.· [noparse][[/noparse] Will someone at the store be able to say, definitively, "Yea, Yea" or "Nay, Nay"? ]· Mine is a Gold-X and it works.
I prefer keeping my life simple and hassle-free. In that spirit, I'd pick the Parallax converter.
Interestingly, I found this at ·http://en.wikipedia.org/wiki/Serial_port·:
The vast majority of personal computer motherboards still have at least one serial port. However some may only have a pin header, and a fly lead is required to bring the connector out through the case. Small-form-factor systems and laptops, however, often do not include them in order to conserve space. RS-232 has been standard for so long that the circuits needed to control a serial port became very cheap and often exist on a single chip, sometimes also with circuitry for a parallel port.
If that's true of your desktop's mobo, you could hack a serial cable and plug it on your mobo's connector.
'serial' (this being a sometimes devious world where people will sell you almost anything) I might not???
And one last question - if I hook up something that isn't quite compatible I can just expect it not to work, I shouldn't expect any damage to
either device?
Thanks again. You've all been a great help.
Prune Free.
2. If it says "Belkin", it probably won't work. If it says "PDA", it probably won't work. If it says "KEYSPAN" or "FTDI", it will definitely work. If you buy it from Parallax, it will definitely work, IF you load the USB to serial drivers properly.
(15.00). Neither store could tell me if they would or even should work.
Neither did. I've already returned the RS one, the other I'll have to wait until tomorrow.
What I get in the Basic Stamp Editor (v 2.1) is an 'invalid port' when I try to communicate with the BS2 with the identify procedure. I don't know if
that's what normally happens, but I'm guessing it is. The program acts as though nothing was hooked up to the com port. It finds the port just fine, just
doesn't manage to talk with it. It acts the same if I have the BS2 attached as it does if I don't.
What is making me nervous though is I hooked all this up to an older Win 98 machine that I have just normally collecting dust that does have a serial port on it and got the same
message (invalid port). I'm hoping that maybe it's just the batteries I have (though I've tried both 9 volt and the 4 pack AA's).
So tomorrow after work I figure I'll see if the big computer store across the river will have serial cards and at the same time pick up some fresh batteries. Hopefully one or the
other will get me started with this.
After that, I guess it's order from Parallax, which I didn't want to do because I hate waiting for stuff to get here. But, I guess if this goes on much longer, the time involved, along with the
trouble will pretty much be a wash, huh?
Prune Free.
'invalid port' seems like an odd message. Remember that the Stamp has to have power or it won't identify itself to the PC.
sell cable adapters for USB to serial, so I've finally broken down and ordered the serial to USB adapter from Parallax. It's out of stock so I ordered the parts individually (they had that - both, just not
bundled). Hopefully they'll give me the bundled price, but I don't think so...
I'll download the latest version of the Stamp Editor and hook it all up and see what happens once my stuff gets here. With luck, that'll solve my problems.
Thanks for your comments and help.
Prune Free.
I got the cable and USB adapter from Parallax today, downloaded the 2.4 version of the Stamp Editor
and all the problems disappeared like magic!
I didn't keep the 2.0 version on my machine, so I don't know if the problem was the cables or the programs.
At this point I guess it doesn't matter too much until someone else bumps into the same problem. If that happens, I'll load the
older version of the Stamp Editor back on just to see what happens. Until then, I'm a happy puppy.
Thanks for your help and suggestions.
Prune Free.
