Need help on Passive infrared motion sensor
First I'ld like to say hello, my name is Mark and I live in NC. When it comes to BS I am totally at a standstill. I have the Parallax PIMS #555-28027 which was given to me because I figured I could put it to use. My situation is that I do alot of photography and my idea is to connect this component to a disposable flash and have it set off by motion, possibly make it adjustable so it doesn't behave too sensitive. I have never used a BS though I have the concept down. I need someone to tell me through a diagram the simplest way to create the programmer and then some basic instructions on how to use it. I also need to know from someone that has used this component a design that will set off the flash say from a drop of water or if possible a combination with a sound trigger. I've tried many of the DIY's on the net but none have worked as well as I expected. See so what I am asking is HELP and alot of it ; with the flash circuit, the BS (how to make and use) and possibly the addition of a sound trigger. If all I get is the motion sensor working I will be extremely happy. Last question; I have a few different PICxxxxx IC's and I wanted to know if they have to be programmed before use or do they have a function already placed in memory? Thanks to anyone who takes the time to help me on this, I am definitely a Noob when it comes to this. You can use my email to respond also it is : markliva@gmail.com
PICs are a whole different story. They do have to be programmed to use them. The BS1 and BS2 use a specially programmed PIC that contains a proprietary Basic interpreter which is what executes your Stamp program.
As Far as making a programmer is there an easy way? I don't have a serial port and was wondering if it can be run through the parallel port or usb?Also noticed there are a number of different programmers to choose from so which is the best or easiest to start with?
