Transistors
Hello,
Is it possible to limit the voltage that passes through a transistor by increasing the value of the resistor back??? I have done this in the past but·I feel like it is not really the right way to do things. In the past situation·I was using tip 29a. However,·I recently tried to do this with a tip 120 and the circuit acted really weird and didnt really work. I figured it was because of the darlington setup in the tip 120.
Thanks for the help...
rr
rr
Is it possible to limit the current that passes through a transistor by increasing the value of the resistor back???
Normally you would limit the current through a transistor by using a resistor or other load impedance. This is used to limit the base current and to limit the collector current (different amounts ... different resistors).
Perhaps a Voltage divider?
Transistors have 3 legs: the Emitter, the Collector, and the Base. The Base is one that is used for control.
5 volts/ 330 ohms = .0151 amps or 15.1 millamps. You really don't want to go much higher than 20-25ma.
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
