Eagle Help - removing "Keepout" area from a device?
Hi all,
I'm using Eagle to design my circuit, and I'm using a L7812CZ voltage regulator in TO-220FP packaging. My problem is, I want to screw the heatsink into my ground-plane for heat dissipation, but the package has "keepout" and "restrict" areas around the screw hole, therefore preventing my ground plane from adequately connecting to the screw?
A simple delete does not work, so I was wondering how can I delete these areas so that I can finish my circuit?
Many Thanks in advance,
Morrolan
Flying is simple. You just throw yourself at the ground and miss.
"I think computer viruses should count as life. I think it says something about human nature that the only form of life we have created so far is purely destructive. We've created life in our own image."
Stephen Hawking
Morrolan
Stephen Hawking
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
