Propeller Tool v1.1 and wine
Hi,
Does anybody have this working. 1.0.5.5 seemed to work, but I didn't try the download. I just removed 1.0.5.5.and installed v1.1 and tried to run it under wine.
Has anybody gotten this to work?
I get the following, quite lengthy error message:
Any help would be appreciated as not having the tool available under linux has prevented me from doing a lot with the propeller in actual code.
Playing "air propeller"
isn't nearly as fun.
Doug
fixme:setupapi:SetupDiClassGuidsFromNameExA
fixme:setupapi:SetupDiGetClassDevsW ({4d36e978-e325-11ce-bfc1-08002be10318}): stub
wine: Unhandled page fault on read access to 0x011c23e4 at address 0x0000:0x004038ee (thread 0009), starting debugger...
First chance exception: page fault on read access to 0x011c23e4 in 32-bit code (0x004038ee).
Register dump:
CS:0073 SS:007b DS:007b ES:007b FS:003b GS:0033
EIP:004038ee ESP:0033f3bc EBP:0033f8b0 EFLAGS:00010206( - 00 - RIP1)
EAX:011c23e4 EBX:0040434b ECX:0033f8b8 EDX:0033f301
ESI:0033f898 EDI:0033f898
Stack dump:
0x0033f3bc: 00404111 00404355 0033f8b8 00403cbb
0x0033f3cc: 011c23e4 0033f810 0033f3fc 0033f414
0x0033f3dc: 00000001 0033f898 7bc77ff4 7bc55975
0x0033f3ec: 0033f810 0033f898 0033f544 0033f494
0x0033f3fc: 0033f884 7bc2f0b0 0033f898 7bc2848f
0x0033f40c: 00160ae0 7e53aff4 0033f434 7bc55947
fixme:ntdll:RtlNtStatusToDosErrorNoTeb no mapping for c0000119
Backtrace:
=>1 0x004038ee in propeller (+0x38ee) (0x0033f8b0)
2 0x004043b0 in propeller (+0x43b0) (0x0033fee0)
3 0x004043ff in propeller (+0x43ff) (0x0033ff08)
4 0x7b86f78e in kernel32 (+0x4f78e) (0x0033ffe8)
5 0xb7eb36d7 wine_switch_to_stack+0x17 in libwine.so.1 (0x00000000)
0x004038ee: movl 0x0(%eax),%ecx
Modules:
Module Address Debug info Name (79 modules)
PE 400000-11b9000 Export propeller
ELF 7b800000-7b91a000 Export kernel32<elf>
\-PE 7b820000-7b91a000 \ kernel32
ELF 7bc00000-7bc83000 Deferred ntdll<elf>
\-PE 7bc10000-7bc83000 \ ntdll
ELF 7bccd000-7be00000 Deferred libcrypto.so.0.9.8
ELF 7bf00000-7bf04000 Deferred <wine-loader>
ELF 7c73e000-7c754000 Deferred libnsl.so.1
ELF 7c754000-7c787000 Deferred libcrypt.so.1
ELF 7c787000-7c7c4000 Deferred libssl.so.0.9.8
ELF 7c7c4000-7c7f4000 Deferred libcups.so.2
ELF 7c821000-7c854000 Deferred uxtheme<elf>
\-PE 7c830000-7c854000 \ uxtheme
ELF 7c854000-7c85a000 Deferred libxfixes.so.3
ELF 7c85a000-7c864000 Deferred libxcursor.so.1
ELF 7c86d000-7c877000 Deferred libnss_nis.so.2
ELF 7c877000-7c87f000 Deferred libnss_compat.so.2
ELF 7c885000-7c88f000 Deferred libnss_files.so.2
ELF 7c891000-7c8ae000 Deferred imm32<elf>
\-PE 7c8a0000-7c8ae000 \ imm32
ELF 7c8ae000-7c8b3000 Deferred libxrandr.so.2
ELF 7c8b3000-7c8bc000 Deferred libxrender.so.1
ELF 7c8bc000-7c8c0000 Deferred libxinerama.so.1
ELF 7e0c0000-7e304000 Deferred i915_dri.so
ELF 7e304000-7e30c000 Deferred libdrm.so.2
ELF 7e30c000-7e367000 Deferred libgl.so.1
ELF 7e367000-7e36b000 Deferred libxau.so.6
ELF 7e36b000-7e371000 Deferred libxdmcp.so.6
ELF 7e371000-7e48e000 Deferred libx11.so.6
ELF 7e48e000-7e49d000 Deferred libxext.so.6
ELF 7e49d000-7e4b6000 Deferred libice.so.6
ELF 7e4b6000-7e544000 Deferred winex11<elf>
\-PE 7e4d0000-7e544000 \ winex11
ELF 7e614000-7e63f000 Deferred libfontconfig.so.1
ELF 7e66c000-7e6d8000 Deferred libfreetype.so.6
ELF 7e6da000-7e6e4000 Deferred libsm.so.6
ELF 7e6e4000-7e705000 Deferred libexpat.so.1
ELF 7e705000-7e71a000 Deferred shfolder<elf>
\-PE 7e710000-7e71a000 \ shfolder
ELF 7e71a000-7e776000 Deferred setupapi<elf>
\-PE 7e730000-7e776000 \ setupapi
ELF 7e776000-7e813000 Deferred comdlg32<elf>
\-PE 7e780000-7e813000 \ comdlg32
ELF 7e813000-7e86c000 Deferred shlwapi<elf>
\-PE 7e820000-7e86c000 \ shlwapi
ELF 7e86c000-7e956000 Deferred shell32<elf>
\-PE 7e880000-7e956000 \ shell32
ELF 7e956000-7e987000 Deferred winspool<elf>
\-PE 7e960000-7e987000 \ winspool
ELF 7e987000-7ea48000 Deferred comctl32<elf>
\-PE 7e990000-7ea48000 \ comctl32
ELF 7ea48000-7ea5d000 Deferred lz32<elf>
\-PE 7ea50000-7ea5d000 \ lz32
ELF 7ea5d000-7ea70000 Deferred libresolv.so.2
ELF 7ea70000-7ea83000 Deferred libz.so.1
ELF 7ea83000-7ea9d000 Deferred version<elf>
\-PE 7ea90000-7ea9d000 \ version
ELF 7ea9d000-7eaef000 Deferred rpcrt4<elf>
\-PE 7eab0000-7eaef000 \ rpcrt4
ELF 7eaef000-7eb84000 Deferred ole32<elf>
\-PE 7eb00000-7eb84000 \ ole32
ELF 7eb84000-7ec1d000 Deferred oleaut32<elf>
\-PE 7eba0000-7ec1d000 \ oleaut32
ELF 7ec1d000-7ec64000 Deferred advapi32<elf>
\-PE 7ec30000-7ec64000 \ advapi32
ELF 7ed48000-7edff000 Deferred gdi32<elf>
\-PE 7ed60000-7edff000 \ gdi32
ELF 7edff000-7ef36000 Deferred user32<elf>
\-PE 7ee20000-7ef36000 \ user32
ELF 7efad000-7efd3000 Deferred libm.so.6
ELF 7efd4000-7efda000 Deferred libxxf86vm.so.1
ELF 7efe1000-7f000000 Deferred iphlpapi<elf>
\-PE 7eff0000-7f000000 \ iphlpapi
ELF b7d35000-b7d39000 Deferred libdl.so.2
ELF b7d39000-b7e67000 Deferred libc.so.6
ELF b7e67000-b7e7f000 Deferred libpthread.so.0
ELF b7ea0000-b7eac000 Deferred libgcc_s.so.1
ELF b7eac000-b7fbe000 Export libwine.so.1
ELF b7fbf000-b7fdc000 Deferred ld-linux.so.2
Threads:
process tid prio (all id:s are in hex)
0000000a
0000000c 0
0000000b 0
00000008 (D) Z:\windows\c\Program Files\Parallax Inc\Propeller Tool v1.1\Propeller.exe
00000009 0 <==
isn't nearly as fun.Thanks,
Doug
Do you have PropTool v1.1 working with reliable downloads to propeller on CrossOver?
If so, what version of CrossOver? What version of Linux?
Doug
Downloads were the one thing I never got to work. I could compile
to a file and use the Python downloader separately.
Is a q6600 quad core with 4GB memory, and 800GB of disk not a real computer?
Just what do you mean?
The more I know, the more I know I don't know.· Is this what they call Wisdom?
a real computer can be easily defined·as it's usefulness to your task(s).
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
I would agree with you, to a point, but unfortunately, my primary task is not prop programming. It is right now a hobby.
My home desktop computer(q6600 based) with SuSE 10.3 works great for browsing the web, email, compressing audio/video, legal document preparation, backup compression and cataloging, video playback, torrent server, etc, etc, etc.
It would make a great gaming machine, but I don't have time, and don't want to risk installing Windows again on it.
My notebook T350P with SuSE 10.2 is much less equipt to handle compresion, a/v, etc, but is very portable, and has plenty of power to handle proptool.
With most any task I give my computers, my primary concern is data security, which precludes me from running Microsoft anything. One of my latest runins with Microsoft Windows 2K, wiped out my partition table on my 750GB Hard Drive. It was only supposed to intall into a pre created 9GB partition, but instead wrote it's own partition table on the disk, and overwrote the beginning of a 700+GB encrypted partition. I lost a lot of data that day, and the blame rests squarely on the M$ Win2K Installer. That is not data security.
I would like to get proptool working on it so I can generate code and upload to the propeller. If you have any information that could help me, I would appreciate it.
Doug
if i come across anything usefull, i'll let you guys know.
E3 = Thought
Doug
I have been trying to get crossover office to install the PropTool1.1 but I get the error
"1155: File Y:\INSTMSIA.EXE not found"
did you find some way around that?
Doug
Has anybody gotten downloading to demoboard from Crossover Office to work?
Doug
Doug
Do you use the Python loader?
I get the same "squooshed hex" display with PropTool 1.1 under CrossOver Mac with a Win2000 bottle.
I have used the Python downloader, but I normally use VMWare and Windows XP to run the PropTool.
