Fixed Point ASIN ? — Parallax Forums
Fixed Point ASIN ?
epmoyerepmoyer Posts: 314
edited 2008-04-04 12:19 in Propeller 1
Is there a fixed point Arc Sin (ASIN) routine out there for the Propeller?
I'm looking to use it in a Hydra game (SpaceWar). My concern is that the best way to do it is probably some kind of a newton's method search of the sin table, which is bound to be both non-deterministic (i.e. take different amounts of time depending on the query value), and be dog slow.
For what I'm doing it may be sufficient for me to create my own reverse lookup table with limited angular resolution (its just a game, after all [noparse]:)[/noparse], but if there was something usable out there already I'd rather make use of it.
    edited 2007-05-02 20:14
    I'm not aware of any arcsine routines other than in the floating point package. Consider using a binary search of the sine table in ROM. With 2048 (actually 2049) entries, the worst case is 11 probes (comparisons). The search time is value dependent, but there are strong bounds on time.
  • Beau SchwabeBeau Schwabe Posts: 6,574
    edited 2007-05-02 22:12
    empoyer,
    Here is a reverse sine lookup method using 11 iterations that is exactly what Mike describes.
    The main core of it (Function Engine) written in assembly is really all that is needed.
    Beau Schwabe
    IC Layout Engineer
  • JasonEJasonE Posts: 16
    edited 2008-04-02 18:03
    Hello,
    · Is there a way to use or modify the code that Beau posted in a manner that does not·require an extra cog?
    ·I am cog limited at the moment and am (unfortunately) not very strong in assembly.
    Any thoughts or guidance would be appreciated!!!
    -Jason
    edited 2008-04-02 19:47
    JasonE,
    If you already have an object written in Assembly, you can cut-n-paste the required portions of my code into your Assembly object....
    Alternatively you could use spin from your main cog... I'll look and see, but I don't think I have it any more. Originally before I converted
    the function to Assembly it was in Spin.
    Beau Schwabe
    IC Layout Engineer
  • stevenmess2004stevenmess2004 Posts: 1,102
    edited 2008-04-02 20:48
    You can make binary searches take a constant amount of time if you want. Have a look here en.wikipedia.org/wiki/Binary_search
    edited 2008-04-03 14:24
    ·· I don't have assembly code I feel I can modify to accomodate the asin code.· What I've done in the meantime is implemented a Taylor series approximation: asin(x) = x + 1/6x^3 + 3/40x^5, which quickly starts to diverge for large angles (x > 0.7, angles·> 45 ) even with higher order terms added (5/112 x^7...).
    · Beau, if you happen to come across the spin implementation I would appreciate it.
    Thank you all for your input!
    -Jason
    edited 2008-04-04 04:35
    JasonE,
    About the only thing I could fine was a Program that I wrote in QuickBasic4.5 to prove the concept.··It's simply a software version of the classic game ... "guess what number" in as few steps as possible.· The only feed back you get is if the 'actual' number is higher or lower than the guessed number.
    If you don't need as much·accuracy, then you can shorten the number of steps.· 11-steps were used to correlate with the 13-bit resolution of the sine table built in the Propeller ROM.· The "missing" two bits are because the ROM table only holds 1/4 of the Sine table (... or 11 bits) the other two bits are derived by translation. (Flipping/Mirroring)
    ARCSIN = 1                              'Range from -1 to 1
    Pi# = ATN(1) * 4                        'Build 1/4 Sine Table
    DIM SineTable(2048)
    Index = 0
    FOR Deg = 0 TO 90 STEP 90 / 2048
        Rad = (Deg / 180) * Pi#
        SineTable(Index) = SIN(Rad)
        Index = Index + 1
    NEXT Deg
                                            'Find ArcSin Value
    RefHigh = 2048                          'Set Ref HIGH
     RefLow = 0                             'Set Ref LOW
      Pivot = (RefHigh + RefLow) \ 2        'Set Pivot point
       Sign = SGN(ARCSIN)                   'Preserve sign of ARCSIN value
     ARCSIN = ABS(ARCSIN)                   'Convert ARCSIN to absolute value
    FOR Iterations = 1 TO 11                'Solve ARCSIN in 11 iterations
        IF SineTable(Pivot) > ARCSIN THEN   'Get 'Pivot' SineTable value and
                                            'compare
           RefHigh = Pivot                  'If 'Pivot' SineTable value is
                                            'greater than the ARCSINE value
                                            'then adjust RefHigh to equal Pivot
        ELSE
           RefLow = Pivot                   'If 'Pivot' SineTable value is
                                            'less than or equal to the ARCSINE
                                            'value then adjust RefLow to equal
                                            'Pivot
        END IF
        Pivot = (RefHigh + RefLow) \ 2      'Re-define Pivot point based on
                                            'RefHigh and RefLow values.
    NEXT Iterations
    ARCSINDeg = Sign * ((Pivot * 90) / 2048)        'Calculate answer in Degrees
    ARCSINRad = Sign * ((Pivot * (Pi# / 2)) / 2048) 'Calculate answer in Radians
    CLS                                     'Clear Screen
    PRINT ARCSINDeg                         'Display answer in Degrees
    PRINT ARCSINRad                         'Display answer in Radians
    ·Note: In QuickBasic4.5 code, the ''/" division bar indicates standard floating point division.· When the "\" division bar is used·it indicates integer division.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 4/4/2008 4:40:40 AM GMT
    Beau,
    · Thank you very much!· This is something I can work with!· I appreciate you taking the time to find this.
    -Jason
