Hitt data logger vs. memory stick data logger
i am trying to create a data acquisition system for a mini baja competition car and we had previously tried to use the BS2 controller and a memory stick data logger. we found that the BS2 did not have the speed that we needed to take accurate reading for all four shocks and the acceleration at the same time. We had previously purchased the memory stick data logger (uses a flash USB drive) and i was wondering if it was possible to adapt that to the SX. I have all the code that makes it run on the BS2 but since i have very limited experience with the SX i am having trouble updating it to the system. Is this even possible to do (we are under a budget and time constraints). Thanks
UVA Mini Baja Team
UVA Mini Baja Team
The writing speed is·quick until the data file grows·large, then it can take a couple seconds to write.
My suggestion would be to save the data to EEPROM, then after the fact move the data from the EEPROM to the data logger.
Bean
www.iElectronicDesigns.com
Post Edited (Bean (Hitt Consulting)) : 4/1/2008 11:25:14 AM GMT
PAUSE 120
SEROUT TX\CTS, Baud, [noparse][[/noparse]"CD UVAMiniBaja", CR]
GOSUB Get_Serial_Bytes
' Open FrontRight.xls for output (write)
PAUSE 120
SEROUT TX\CTS, Baud, [noparse][[/noparse]"OPW FrontRight.xls", CR]
counter = counter + 1 ' Increment Counter
' Write loop counter value and data separator to DATAFILE.TXT
PAUSE 120
'DEBUG "Writing data separator now... ", CR
SEROUT TX\CTS, Baud, [noparse][[/noparse]"WRF ", $00, $00, $00, $09, CR,
DEC5 counter, "**", CR, LF,CR]
PAUSE 120
DIRH=255
FOR i=1 TO 1000 'data acquisition loop
GOSUB Get_ADC_Data
'DEBUG DEC3 ADCdata,CR
SEROUT TX\CTS, Baud, [noparse][[/noparse] "WRF ", $00, $00, $00, $05, CR, ' writes data to flash drive
DEC3 ADCdata, CR,LF, CR]
'DEBUG "say hello, ",CR
PAUSE 1
NEXT ' end of data acquisition loop
' Close DATAFILE.TXT
PAUSE 120
SEROUT TX\CTS, Baud, [noparse][[/noparse]"CLF FrontRight.xls", CR]
' Change to root folder
PAUSE 120
SEROUT TX\CTS, Baud, [noparse][[/noparse]"CD ..", CR]
' USB Suspend Mode (Power Saving Mode)
PAUSE 120
DEBUG "Putting drive to sleep...", CR
SEROUT TX\CTS, Baud, [noparse][[/noparse]"SUD", CR]
END ' ends program at this point ready for addition of loops
Get_Serial_Bytes:
timeout = 1 ' Set Timeout Indicator Flag
index = 0 ' Initialize Index
marker= 0
DO WHILE (timeout > 0) ' While Timeout Has Not Occurred
'DEBUG "hello get serial bytes",CR
marker = marker+1
ioByte = 0 ' Clear Temporary Storage
SERIN RX\RTS, Baud, 100, No_Data, [noparse][[/noparse]ioByte]
buffer(index) = ioByte ' Save Byte Received To Array
index = index + 1 ' Increment Index
IF (index > 14) THEN ' Check For Overflow
index = 14 ' Prevent Overflow
ENDIF
LOOP
DEBUG "Do loop ran...", DEC marker, " times",CR
RETURN
there is some of the code i am working on it right now but so far i am not getting that far. Also if there is any way to optimize the time that it takes to run that would be great. that is the hardest thing that we have come across so far and if the data does not come in fast enough it is invalid and there is no reason to even take it. all we need is the raw data which we can then convert to what we need in excel.
