RFID No-read BS2
Hey all,
I am having problems getting my RFID reader to read RFID tags. I absolutely definitely have things hooked up properly. Every once in a while when I run the code it detects a tag and displays the info but refuses to do so consistently. I had it up and running perfectly for a couple of times before where it did what it was supposed to do so I know (hopefully) that it works. I am currently using a parallax-brand USB to Serial converter.... I am using sample code directly from the parallax website so I don't think there are any errors there? Anyone else had an RFID work sporadically for them?
Edit: The RFID light is red.
I am currently using this code:
I appreciate any response,
Luke TY
Post Edited (Luke TY) : 3/28/2008 12:28:25 AM GMT
' File....... RFID_basic.BS2
' Purpose.... RFID Tag Reader
' Author..... (c) Parallax, Inc. -- All Rights Reserved
' E-mail..... support@parallax.com
' Started....
' Updated.... 02 Mar 2005
' {$STAMP BS2}
' {$PBASIC 2.5}
' -----[noparse][[/noparse] Program Description ]---------------------------------------------
' Reads tags from a Parallax RFID reader and displays ID to debug screen
' -----[noparse][[/noparse] Revision History ]------------------------------------------------
' -----[noparse][[/noparse] I/O Definitions ]-------------------------------------------------
Enable PIN 0 ' low = reader on
RX PIN 1 ' serial from reader
' -----[noparse][[/noparse] Constants ]-------------------------------------------------------
#SELECT $STAMP
#CASE BS2, BS2E, BS2PE
T2400 CON 396
#CASE BS2SX, BS2P
T2400 CON 1021
#CASE BS2PX
T2400 CON 1646
#ENDSELECT
Baud CON T2400
LastTag CON 3
#DEFINE __No_SPRAM = ($STAMP < BS2P) ' does module have SPRAM?
' -----[noparse][[/noparse] Variables ]-------------------------------------------------------
#IF __No_SPRAM #THEN
buf VAR Byte(10) ' RFID bytes buffer
#ELSE
Char VAR Byte ' character to test
#ENDIF
tagNum VAR Nib ' from EEPROM table
idx VAR Byte ' tag byte index
' -----[noparse][[/noparse] Initialization ]--------------------------------------------------
Reset:
HIGH Enable ' turn of RFID reader
' -----[noparse][[/noparse] Program Code ]----------------------------------------------------
Main:
LOW Enable ' activate the reader
SERIN RX, T2400, [noparse][[/noparse]WAIT($0A), STR buf\10] ' wait for hdr + ID
#ELSE
SERIN RX, T2400, [noparse][[/noparse]WAIT($0A), SPSTR 10]
#ENDIF
HIGH Enable ' deactivate reader
Display_Tag:
DEBUG "Tag Identification number is: ", CR
FOR idx = 0 TO 9 ' scan bytes in tag
DEBUG buf(idx)
#ELSE
GET idx, Char ' read char from SPRAM
DEBUG Char
#ENDIF
NEXT
DEBUG CR
PAUSE 500
GOTO main ' repeats code
Luke TY
Chris Savage
Parallax Tech Support
How are running RFID Card Reader Board
(1) are you running the reader off of·the regulator of the Basic Stamp Board
If this is the case you maybe taxing regulator by over heating it
(2) You should be Running it on it own regulator with a heat sink if
you are using 7.2 volts or more
(3) If you are not using a regulator·for the RFID Card Reader Board·or
·The on board regulator on the·Basic Stamp Board to power the RFID Card Reader Board·
·That is the vdd termanl then you have fried the·· RFID Card Reader Board which i hope is not the case
Parameter Symbol Conditions Min. Typ. Max.
Supply Voltage VCC --- 4.5 5.0 5.5 V
Supply Current, Idle IIDLE --- --- 10 --- mA
Supply Current, Active ICC --- --- 90 --- mA
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 3/28/2008 5:45:12 PM GMT
Chris, The light does turn green when a tag is read. It does detect tags but very rare and sporadically.
How are you placing the card to the reader
·Are you putting the card to the center of the cut out on the RFID Card Reader Board·if not try this
·Are you using the round disk or the card type with round ones put·at where you see the traces·around ·the cut out· and move to the top off
the card reader until it reads the card and then leave it until it reads it couple of times
If you are using the card type just set the card on top of the card reader a Little·more to the top of the card reader this is the end of the card reader that dose not have the pins
You will know if you have the card in the right place because it keep reading the same number for that card
It will read a card or disk ·about one every second or so
Also did you use the pin that are list on the DEMO Code· which would be pin 0 and pin 1 on the board that you are using
One other thing are you using the plug in part on the white plastic pro-to board if this is the case your connection may not be very good
a connector that is made for the pins on the board
One more thing make sure that the card or disk are·as close to the·RFID Card Reader Board as you can and only use one card or Disk·one·at time
I hope this help·you get the reader to work right
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 3/29/2008 8:12:40 AM GMT
Chris Savage
Followed all suggestions and am still having the same problem.
Please contact Tech Support directly to send the device in for testing. support@parallax.com
Chris Savage
