Ground?
I have an App that uses an ezLCD and I am laying out a board to backpack on the screen. The connector has 4·analog Ground·pins·and 1 Signal ground pin. The prop and the LCD will use the same Battery, but use different regulators. The Prop communicates with the LCD via· TTL rs232. What is the best way to tie in the Props ground lines.
I can post a schematic of what I have later tonight, but maybe someone knows already!
Is this the proper oreintation for the logic and analog grounds?
Please ignore the missing passive components. I've yet to create component pads,because I'm not sure what kind I'm going to use yet!
1) Avoid ground loops
2) Avoid noise on the analog supplies (I.E: Nothing digital should be connected to it, and it should preferably both the digital and analog supplies should branch from the main supply directly after the filtering).
3) Minimize resistance between any two analog grounding points to as close to 0 as possible.
The main thing to consider is avoiding anything which causes the voltage of a supply rail to change.
