rf transmitter burned :( — Parallax Forums
earl_24earl_24 Posts: 9
edited 2008-03-28 22:29 in BASIC Stamp
can you tell me please what represent the element from the image? It is burned and i must change it.
    edited 2008-03-28 19:39
    Hello,
    That is a 10uF Tantalum SMD capacitor used for filtering the supply lines coming into the module. If it has been damaged and the transmitter does not work, this is most likely due to over-voltage on the power supply pins and there is likely more damage than just that capacitor.
    Chris Savage
    Parallax Tech Support
  • stephenwagnerstephenwagner Posts: 147
    edited 2008-03-28 19:52
    Ten (10) followed by six (6) zeros, units of measure, pico farid (pF) capacitor.
    10000000 pF
    10000 nF
    10 uF
    It is a 10 uF electrolitic capacitor. Probly on the order of not to exceed·5 to 15 working volts DC. The band is the positive end.
    Did you apply more then 5 VDC to the device???
    More then 5.2 VDC to the RF module will damage the RF module.
    The TXM 433 LR S data sheet can be found here under LC (low cost) LR (long range) links.
    http://www.linxtechnologies.com/Products/RF-Modules/LC-Series-Low-Cost-Transmitter-and-Receiver-Modules/
    I hope this helps.
    SJW
    edited 2008-03-28 20:09
    Applying a reverse voltage to a tantalum cap will destroy it, too, sometimes spectacularly.
  • earl_24earl_24 Posts: 9
    edited 2008-03-28 20:46
    thanks guys. if I will change the capacitor there is a chance that the RF transmitter will work again?
    edited 2008-03-28 21:33
    What did you do to damage the unit? Over-voltage or reverse polarity?
    Chris Savage
    edited 2008-03-28 22:11
    reverse polarity
    That may have damaged the Lynx chip.
    Chris Savage
