Penguin Or Boebot
This will be my first time getting involved in robotics a have some electronics knowledge and understand what componenets do but was wondering which robot would be the best to purchase as a begginer?
- a boebot with the ping))) sensor
- The penguin Robot
- The penguin Robot
The BoeBot has the advantage that it's wheeled and therefore faster, has bigger batteries that are rechargable, and allows you to do hardware experimentation with many detailed tutorials for the BoE.
The Penguin is cuter by far and you can do pretty much anything in terms of software experimentation that you can do with the BoeBot.
Post Edited (Mike Green) : 3/27/2008 11:10:13 PM GMT
mike green - thanks a little cart good idea [noparse]:D[/noparse]
The articles I'm writing will get into hacking into the Scribbler's I/O lines for expansion. There is already a "hacker port" inside the case for access to the 3 I/O lines that drive three green LEDs, and the three photocells each have an I/O ripe for the taking. There's tons of Boe-Bot info that translates directly over to the Scribbler as well, they're similar in many ways.
I've probably offended some diehard Boe-Bot fans, but what a great topic for discussion. Can't wait for the spirited rebuttals!
could i use a propeller chip in the BoE ? as it looks like it would be quite a good way to start to learn programing parallel processing or is it to ambitious
on a boe bot frame, it looks like just about everything has been replaced with one larger breadboard (the Propeller Education Kit) but I guess it does show that it can be done. Provided you
know a lot more about them than I do.
Prune Free.
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/List/1/ProductID/448/Default.aspx?txtSearch=spin+stamp&SortField=ProductName%2cProductName
so can use the propeller chip in the BoE or do i have to buy the development board because i like the solder-less breadboard quite a bit (as im sure it would be good for beginners) i could always progress to a Propeller Boebot Development board.
will
http://www.elektor.com/magazines/2007/july-august/propeller-prototyping-board-for-boebot.197579.lynkx
i have the issue (ebook) if anyone wants a link for it.....
