Performance questions
I was wondering whether the Propeller could do
DFT or Goertzel algorithm for signals less than 1kHz,
and how fast it could save a word to USB flash memory
or SD memory.
- Thanks.
or SD memory.
- Thanks.
Saving to SD is very fast.· This would not be a limiting factor.
I don't know how to translate a requirement in sampling
rate to a requirement on the code size or memory size.
That is the my missing knowledge.
I read a post on the Basic Stamps forum that the Basic Stamps
board could not do DFT. The problem was in both speed and
memory. I was also considering the Arduino processor, but
it seemed that the Arduino was similar to a Basic Stamp.
The acceptable sampling rate was 2000 per second.
I don't know how to translate this to hardware requirement.
It would be ok to do DFT on 1024 points. Although this could be
much fewer using Goertzel. Are these two parameters enough
to estimate the performance with or without floating point?
( I have just realized that I was asking for a benchmark. )
About saving:
Did you imply that saving to USB is a lot slower? and might be
a limiting factor?
- Thanks
Reference to Basic Stamp:
http://forums.parallax.com/forums/default.aspx?f=19&m=42878&g=42895#m42895
Reference to another post on FFT using Propeller
http://forums.parallax.com/forums/default.aspx?f=25&m=119048&g=120533#m120533
Post Edited (Edgar) : 3/26/2008 7:34:48 PM GMT
There is no native way to send large amounts of data via USB. You'd need some kind of 3rd party device.
(although, if you are using the PropPlug, that will let you send data up to 2MBPS or so to the PC over USB).
Post Edited (Rayman) : 3/26/2008 8:26:52 PM GMT
I ported some mDCT and iFFT routines into SPIN when I was looking into MP3 decoding, but these were only 32 samples...
Use this URL:
http://forums.parallax.com/showthread.php?p=711145
Aka: CosmicBob
http://forums.parallax.com/forums/default.aspx?f=25&m=204569
on 1-bit delta-sigma ADC. I read the concept from this page
http://members.cox.net/brookhaven-north/Parallax/PropellerSpectrumAnalyzerforAudio.html
and tried different parameters using on Excel. It looks like it works,
but I am missing the theoretical background to justify that it works.
I am going to post the algorithm so that people can tell whether
something is wrong with it or how I estimate the performance.
- Thanks
