How to pass a variable from spin to assembly and vice-versa?
Hi,
In this piece of code that i'm using, i seem not be be able to update the value of the variable _comparatorPosition from the spin part to use in the asm part for comparison. Can anybody tell me what I'm doing wrong?
CON
_CLKMODE = XTAL1 + PLL16X
_XINFREQ = 5_000_000
MAX_LENGTH = 400
PIN_ENCODER_BOX_A = 3
PIN_ENCODER_BOX_B = 4
'PIN_ENCODER_BOX_I = 5
'PIN_ENCODER_PP_A = 5
'PIN_ENCODER_PP_B = 6
'PIN_ENCODER_PP_I = 8
OBJ
_Encoders : "Quadrature Encoder"
_BS2 : "BS2_Functions"
_Serial : "Extended_FDSerial"
VAR
long _position[noparse][[/noparse]2]
long Stack
PUB Main | triggerSign, input, Duration, cntMin
_BS2.start(31, 30)
_Serial.start(1, 0, 0, 9600)
_Serial.str(string("Position calculator..."))
_Serial.SetDelimiter(" ")
_Serial.str(string("Enter the trigger position value:"))
repeat
_triggerPosition := _Serial.RxDec
if _triggerPosition
_Serial.dec(_triggerPosition)
quit
_Serial.str(string("Enter duration of the pulse:"))
repeat
Duration := _Serial.RxDec
if Duration
_Serial.dec(Duration)
quit
cntMin := 400
Delay := (Duration * (clkfreq / 1_000_000) * 2 - 1250) #> cntMin
_Serial.dec(Delay)
'Encoder
_Encoders.start(PIN_ENCODER_BOX_A, 1, 0, @_position)
_comparatorPosition := 0
cognew(@Trigger, 0)
repeat
_comparatorPosition := _position[noparse][[/noparse]0]
DAT
org 0
Trigger cmp _triggerposition, _comparatorPosition wz
if_nz jmp #:notEqual
or dira, Led1
xor outa, Led1
or dira, Pin
mov Time, cnt
add Time, #9
waitcnt Time, Delay
xor outa, Pin 'high
waitcnt Time, Delay 'wait untill time
xor outa, Pin 'low
jmp #trigger
:notEqual or dira, Led2
xor outa, Led2
jmp #trigger
Pin long |< 6
Led1 long |< 16
Led2 long |< 23
Delay long 0
_triggerposition long 0
_comparatorPosition long 0
Time res 1
To get around this you need to use the hub access instructions. In this case rdlong. You also need the address of _comparatorPosition and a way of passing it to the cog. So you need to change your cogne to this to pass in the address of _comparatorPosition
Note that this passes in the hub address and not the cog address. Than you need to change the first line of your assembly routine to this
Trigger rdlong _comparatorPosition,par 'This gets the long from the hub and stores it at _comparatorPosition in the cog cmp _triggerposition, _comparatorPosition wzHope this helps
Since you are setting _triggerPosition before you start the cog and never change it after you start the new cog the value you write there will get copied into the cog and will therefore work as expected.
http://forums.parallax.com/showthread.php?p=647408
it works just fine.
