Looking for some info from the Gurus
iave two devices that need to work together.·· One is·an HID device that toggles a line. first time it is·high- and changes to low_.· so -_.· the next time that it triggered it goes from low_ to high-.· so _-.· the second device that it is talking to wants to see a Low to high to low. or a High to low to high.· i can make it work with either.
So here is the problem,· The second device wants to see -_- in order to do its function.
that means that i have to activate the HID device twice to get it to move from -_ and _- to accomplish this.
I only want to activate the HID once to trigger the second device, so i need to make an interface that will go between the two devices.·
it needs to take the -_ and create a -_- and then the next time it will see a _- and will again put out a -_-.
Any ideas will be greatly appreciated.
It's Only A Stupid Question If You Have Not Googled It First!!
For anyone else that wants to do this without a controller, I would think that an XOR gate where the input went directly to one input, and and RC on the other input would do the job too.
The XOR output should be low normally. When the Toggle Output changes you should get a high pulse on the XOR output related to the R and C values.
Bean.
www.iElectronicDesigns.com
Post Edited (Bean (Hitt Consulting)) : 3/24/2008 1:23:56 PM GMT
