Array of objects question
Anyone care to explain why I don't get·6 "Hello World!" lines from this spin program ?
TIA
jazzed·... about·living in·http://en.wikipedia.org/wiki/Silicon_Valley
Traffic is slow at times, but Parallax orders·always get here fast 8)
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 ' _clkmode = xtal1 + pll8x ' _xinfreq = 10_000_000 OBJ s[noparse][[/noparse]6]: "FullDuplexSerial" PUB main | ii repeat ii from 0 to 5 s[noparse][[/noparse]0].start(31,30,0,28800) s[noparse][[/noparse]0].rx ' pause for user repeat ii from 0 to 5 s[noparse][[/noparse]ii].str(string("Hello World!",$d))
TIA
Why is it that if i use one set of pins, the output fails to print one line ?
If I change "s[noparse][[/noparse]ii].start(ii+5,ii,0,28800)" to "s[noparse][[/noparse]ii].start(31,30,0,28800" for example,
I get "Hei" and that's it.
The "Hei" is the start of the first s[noparse][[/noparse]ii].str(...) before you kick the next cogs into action with their start(). As soon as they kick in they force Pin 31 high, corrupting the last character you saw and putting the line high.
That's my 'best guess' anyway.
From a high level the answers are clear. There are some ASM questions related to this whose answers are unclear:
1. If i declare variables in the DAT section as is done in the serial object, are these considered global or local?
On the transmit side of the object as in the example above, the variables seem to be mutually exclusive.
2. Is the RES declaration for variables in the serial object making the variables local to cog ram ?
3. If I use selfmodifying code in an ASM object pointing to RES or LONG data, will this change be only local to the COG?
TIA
Variables declared in a DAT section are common to all instances.
You have to remember that a cog is started by copying a block of 512 longs to the cog's memory from hub memory. The last 16 longs are special registers which are zeroed if they're read/write, but the cog goes through the motions of copying 512 longs. If the data in hub memory is less than 512 longs, whatever stuff is beyond is copied anyway. BYTE / WORD / LONG actually allocate space in hub memory and initialize it (as do instructions). RES just advances the cog memory address so labels get declared properly in cog memory, but there's no storage actually allocated or initialized. That's why RES has to be last in the DAT section.
When the code actually executes, any use of RES or LONG data is cog memory. The only way to access hub memory is with the hub instructions (RDxxxx / WRxxxx).
However, unless the FullDuplexSerial.spin ASM variables in the DAT section are mutually exclusive,
I don't see how 6 separate instances of the object could work correctly. Please explain.
If the cog is started by copying a block of longs, then how can the DAT section variables be common?
I know from experience that DAT variables are common. This is very confusing.
Also if a block is copied for the cog, I assume all code would be mutually exclusive at run time; correct?
I am very concerned about self-modifying code only being changed within one cog and not others.
TIA
Assembly instructions all operate on cog local variables except for the WRLONG/WRWORD/WRBYTE instructions, which write to hub ram, and RDLONG/RDWORD/RDBYTE instructions, which read from hub ram.
Any changes in cog ram do not affect those in hub ram. Any changes in hub ram don't affect cog ram.
Any values that are specific to a single instance of a spin object will be stored in a VAR section, and a pointer to them passed to the cog when it is started.
So DAT vars are common for SPIN (hub), but not ASM (cog). Former is supported by tons of experience; the latter is still questionable. Yes RD/WR* instructions clearly access hub memory ... no questions there [noparse]:)[/noparse]
I'll continue on the thesis that once a cog is started, it's DAT instructions and variables are his/her own and no other cog accesses them (i must have a bug in my asm project that fools me into believing otherwise). Thanks for your patience [noparse]:)[/noparse]
Paul Baker
Post Edited (Paul Baker (Parallax)) : 3/23/2008 9:36:08 PM GMT
Looking at the FullDuplexSerial code however, some variables t1,t2,etc... are
manipulated by rd/wr* instructions, so that is still an open question for me.
Nevertheless ... I am very happy now because ...
In the program I'm developing, I changed the variables that I want to keep local
from initialized "var long x" to "var res 1" and the scope appears to be cog local now.
Too bad I had to add zeroing code at startup for the RES variables ... oh well.
Thanks Guys.
