Another Pair of eyes on SubRoutine Parameter Poblem
John Kauffman
Can anyone spot the problem with code below that communicates with a serial device?
I get an assembly error on both GoSub lines:· "Invalid Number Of Paramaters."
Thanks.
' Device Settings
' external resonator Murata "400C.625"
DEVICE· SX28, OSCHS2, TURBO, STACKX, OPTIONX
FREQ··· 28_000_000
IO Pins
Spin·pin·RA.0·' Serial Pin
· PROGRAM Start
Subroutines / Jump Table
TX_BYTE sub 1
Program Code
Main:
·LOW SPin········· ' Start with serial pin low
·PAUSE 1000······· ' Allow device to stabilize
·GoSub TX_Byte 5
·GoSub Tx_byte "a"
·GoTo Main
TX_Byte:
· SEROUT Spin, N2400 __PARAM1
·endsub
Thanks.
' Device Settings
FREQ··· 28_000_000
IO Pins
· PROGRAM Start
TX_BYTE sub 1
Program Code
Main:
·GoSub TX_Byte 5
·GoSub Tx_byte "a"
·GoTo Main
TX_Byte:
·endsub
I found a few things and I think the code below will do what you want. (don't worry, these are easy things to overlook and everyone does it at least once!)
The part that was causing the error is that when you use GOSUB it doesn't expect to pass any variables. You just need to use the subroutine name alone. I also added the sub and removed the : in the definition of the subroutine to remain consistent. The definition and calling method you had was mixed between the two formats. Since it has changed as SX/B has matured I can see how someone could easily do that.
Another thing that I noticed was that a comma was missing the in SEROUT command.
The last thing it needed was with the PROGRAM Start. Start is a label that doesn't exist in the program. It could have been changed to Main but I just added a Start label since you may way to setup some things before getting to your main code. To help clean up the code I made all the occurrences of TX_BYTE the same case.
Compiles fine now.
' Device Settings
DEVICE SX28, OSCHS2, TURBO, STACKX, OPTIONX
FREQ 28_000_000
IO Pins
Spin pin RA.0 ' Serial Pin
TX_BYTE sub 1
PROGRAM Start
Start:
' Setup variable, etc
Program Code
Main:
LOW SPin ' Start with serial pin low
PAUSE 1000 ' Allow device to stabilize
TX_BYTE 5
TX_BYTE "*"
GoTo Main
sub TX_BYTE
SEROUT Spin, N2400, __PARAM1
endsub
Post Edited (RobotWorkshop) : 3/22/2008 6:07:53 PM GMT
Thanks for your time to provide such a thorough explanation.
