Need to finish project
Hi,
I am almost done programming my microcontroller, but don't know what to do when I'm done because I will need to solder my components to my microcontroller. Does anyone know what to do when programming is complete? I have to use all components in a robot, and I don't think that keeping them in my board of education's breadboard would be a good idea - they might come loose. Is there a board that I can solder too that can be purchased anywhere? I don't have much time to wait for a shipment from parallax.
thank you!
thank you!
This would work just fine Model: 276-147
There are no Undo buttons in life.
Post Edited (Tech-Man) : 3/19/2008 7:02:15 PM GMT
thanks again
www.parallax.com/Store/Microcontrollers/BASICStampDevelopmentBoards/tabid/137/CategoryID/12/List/0/SortField/0/Level/a/ProductID/121/Default.aspx
Max Wooden
Reedley, California
Post Edited (Max Wooden) : 3/21/2008 12:40:07 AM GMT
I hate to nit pick - but you posted a link to the Stamp Carrier board, not the Super Carrier board - which is here www.parallax.com/Store/Microcontrollers/BASICStampDevelopmentBoards/tabid/137/CategoryID/12/List/0/SortField/0/catpageindex/2/Level/a/ProductID/122/Default.aspx
The Super Carrier sells for $4 more than the Stamp Carrier board, and it's more flexible than the Stamp Carrier board. The Super Carrier has a 5 VDC regulator circuit (so you can power other components besides the Stamp), supports the BS1 and BS2 series and has an AppMod connector for expansion.
Max Wooden
Reedley, California
