more volume — Parallax Forums
more volume
RickMRickM Posts: 10
edited 2008-03-20 02:56 in BASIC Stamp
I'm using freqout to the pizo.
I want more volume, how do i do this
thanx
rick
  • Steve JoblinSteve Joblin Posts: 784
    edited 2008-03-18 16:16
    You will want to use an LM386 (http://www.national.com/ds/LM/LM386.pdf) amplifier chip... page 5 shows simple circuits that requires just a few ressitors and capacitors.
  • RickMRickM Posts: 10
    edited 2008-03-18 16:22
    thanx
    it appears the LM386 draws 4ma, can i use power from the basic stamp2 or do i need external power source
    rick
    edited 2008-03-18 17:17
    Here is a great link I just found... http://braincambre500.freeservers.com/LM386 Audio Amp.htm
    I would power the amplifier directly from the your power source.
    edited 2008-03-18 17:30
    RickM,
    This link might help... http://forums.parallax.com/showthread.php?p=464410· I'm not sure that a LM386 in a typical speaker configuration is adequate for driving a piezo.· In other words remove the series capacitor on the output of the LM386 if you decide to go that route.
    Beau Schwabe
    IC Layout Engineer
    edited 2008-03-18 17:49
    Thanx All
    I will try the LM3386 w/ a speaker......
    Now... what if I want to play a .wav file?
    edited 2008-03-20 00:02
    Here's a simple circuit that will provide a higher peak-to-peak voltage to the piezo:
    The two op amp halves are connected as comparators, which compare the filtered input voltage from the Stamp to Vdd/2 (2.5V). (The reason for using an op amp instead of a comparator is that it has both high-side and low-side drive. Most comparators have open collector outputs.) The piezo is driven differentially. On my BOE, with Vin = 12V, I was getting a 20V P-P drive on the piezo speaker.
    Since the output is a square wave, you won't get faithful reproduction of sine waves or dual-tone FREQOUTs. For that you'd have to add feedback to the op amps and treat them as linear amplifiers instead of comparators.
    407 x 340 - 3K
  • roboman01roboman01 Posts: 5
    If you want more volume, then just get a piezo with a higher dB rating.
