Line drawing algorithm, anyone create one in spin? — Parallax Forums
Timothy D. SwieterTimothy D. Swieter Posts: 1,613
edited 2008-04-17 20:39 in Propeller 1
I have been working on my uOLED display driver (clocking data to the OLED from the Propeller) and the graphics driver (an 8-bit graphics engine).· Right now the display driver is working great.· It is written in ASM and the memory in the Prop is being written to the memory of the OLED in about 6ms per frame!
Now, I am trying to piece together some graphics drawing routines.· I am writing them in Spin first and then I will convert to a graphics engine in ASM.· The bitmap memory·color depth is·8-bit per pixel.· I have a plot pixel function working.· Next is a line algorithm.· I looked through the Hydra book and there were only a couple references, nothing major.· I also looked at the Black Art e-book on the Hydra CDROM and that helped a little.· I mostly did searches on Google for Bresenham to read more about his work.
Anyway, has anyone created a line drawing algorithm in Spin that works for all line slopes?· I have a partial line function working, but it only applies to slopes from -1 to 1 and sometimes I think it is still not right.
Timothy D. Swieter
www.brilldea.com·- check out the uOLED-IOC, an I/O expansion for the uOLED-96-PROP
www.tdswieter.com
One little spark of imagination is all it takes for an idea to explode
  • OwenSOwenS Posts: 173
    edited 2008-03-17 15:35
    Slope drawing is gonna need some form of point arithmetic, whether it be fixed or floating point, else errors will accumulate and you won't get the line you want. Bressenham's algorithm is probably the best general line drawing algorithm, but it's by no means ideal: It needs a division, which is certainly not fast without ALU support
    edited 2008-03-17 18:17
    Timothy,
    Give this a try. It's a line drawing algorithm that uses no multiplies or divides and works for any pair of endpoints. I've transcribed it from an assembly routine and haven't tested it, so let me know if it doesn't work and I'll fix it.
    pub drawline(x0, y0, x1, y1) | dx, dy, difx, dify, sx, sy, ds
    'Draw a straight line from (x0, y0) to (x1, y1).
      difx := ||(x0 - x1)           'Number of pixels in X direciton.
      dify := ||(y0 - y1)           'Number of pixels in Y direction.
      ds := difx <# dify            'State variable change: smaller of difx and dify.
      sx := dify >> 1               'State variables: >>1 to split remainders between line ends.
      sy := difx >> 1
      dx := (x1 < x0) | 1           'X direction: -1 or 1
      dy := (y1 < y0) | 1           'Y direction: -1 or 1
      repeat (difx #> dify) + 1     'Number of pixels to draw is greater of difx and dify, plus one.
        drawpoint(x0, y0)           'Draw the current point.
        if ((sx -= ds) =< 0)        'Subtract ds from x state. =< 0 ?
          sx += dify                '  Yes: Increment state by dify.
          x0 += dx                  '       Move X one pixel in X direciton.
        if ((sy -= ds) =< 0)        'Subtract ds from y state. =< 0 ?
          sy += difx                '  Yes: Increment state by difx.
          y0 += dy                  '       Move Y one pixel in Y direction.
    pub drawpoint(x, y)
    'Your point-drawing routine.
  • Jasper_MJasper_M Posts: 222
    edited 2008-03-17 18:44
    Phil Pilgrim (PhiPi) said...
    Timothy,
    Shouldn't those be
      dx := (x1 < x0) + 2           'X direction: -1 or 1
      dy := (y1 < y0) + 2           'Y direction: -1 or 1
    Oops never mind
  • mparkmpark Posts: 1,322
    edited 2008-03-17 21:49
    OwenS said...
    Bresenham doesn't need division.
    Michael Park
    PS, BTW, and FYI:
    To search the forum, use search.parallax.com (do not use the Search button).
    Check out the Propeller Wiki: propeller.wikispaces.com/
    edited 2008-03-17 22:20
    Timothy D. Swieter,
    There is an ASM line function that should work for you from the VGA text and graphics demo... I derived this from the TV graphics demo, but if I remember correctly you must draw the line from BOTH end points to the center or continue to the opposite end once you have determined if the slope of the line is Vertically or Horizontally dominate.
    http://forums.parallax.com/showthread.php?p=606957
    Beau Schwabe
    IC Layout Engineer
  • JT CookJT Cook Posts: 487
    edited 2008-03-17 23:35
    I don't have a line drawing solution, I just had a quesion on the driver. Is it just an bit bitmap that then gets drawn to the OLED? Also how is the palette setup? Any screenshots you can post?
    edited 2008-03-17 23:40
    Thank you guys for the quick response. I tried Phil's algorithm and it works. It looks very familiar after studying the Bresenham's algorithm. As I transisition my way into an ASM algorithm I will look into Beau's post and also dissect the Parallax Graphics ASM.
    Timothy D. Swieter
    www.tdswieter.com
    edited 2008-03-17 23:57
    Hi JT -
    In a couple days I will be making a post with further details about the OLED driver and the basic graphics engine (really just a set of routines at this point).· Yes, the memory is just bitmap memory.· The system is setup with an on-screen memory and an off-screen memory but in reality you could eliminate one and just have the graphics engine and display driver work in series (i.e. draw the image in memory and then update the OLED).·
    There isn't a palette in the driver.· I am using the OLED in 8-bit mode which allows for 256 colors with 3-bits for R, 3-bits for G and 2-bits for blue.· There are some advance features of the OLED for grayscale and PWM adjustment, but I haven't messed with those.· In time maybe the display driver can be expanded.
    Stay tuned for pics/video and·a further post.
    Timothy D. Swieter
    www.tdswieter.com
    edited 2008-03-18 01:56
    Phil - do you happen to have a circle algorithm too? I will credit you in the functions I am creating.
    Timothy D. Swieter
    www.tdswieter.com
  • AndreLAndreL Posts: 1,004
    edited 2008-03-18 02:46
    The integer circle algorithm works in the same manner the line algorithm does, it basically evaluates a "decision" variable. In the circle case, its a 2nd order problem. Anyway, there are a zillion integer circle algorithms on internet, but the source of most of this is "Principles of interactive computer graphics", there is a section that covers these kind of digital differential analysis. I think I might have derived the algorithm in one of my graphics books, but I would have to look. Anyway, its 50 lines of code if that, and then it draw 1 qudrant or octant and you reflect the others. If you want a generalized elipse then its a little less optimized.
    Andre'
    edited 2008-03-18 02:48
    OK. After some Google searches I was started to get the feeling of more complicated alogirthm, that is why I asked here.
    I will focus my attention on a couple other functions to finish before I post the code.
    Timothy D. Swieter
    www.tdswieter.com
    edited 2008-03-18 03:03
    Timothy,
    No, sorry, I don't have one handy. The assembly program that the line routine came from doesn't do circles.
    edited 2008-03-18 04:28
    Thanks Andre for the kick to Wikipedia.· I translated the algorithm found there into SPIN.· Here is the code:
    PUB plotCircle(_x0, _y0, _radius, _color) | f, ddF_x, ddF_y, x, y
    '' Plot a circle with center _x0,_y0 and radius _radius with the appropriate 8-bit color
    ''  _x0, _x1   - coordinate of the center of the circle
    ''  _radius    - radius, in pixels, of the circle
    ''  _color     - 8-bit color value (RRRGGGBB)
      f := 1 - _radius
      ddF_x := 0
      ddF_y := -2 * _radius
      x := 0
      y := _radius
      plotPixel(_x0, _y0 + _radius, _color)
      plotPixel(_x0, _y0 - _radius, _color)
      plotPixel(_x0 + _radius, _y0, _color)
      plotPixel(_x0 - _radius, _y0, _color)
      repeat while x < y
        if f>= 0
          y--
          ddF_y += 2
          f += ddF_y
        x++
        ddF_x += 2
        f += ddF_x + 1
        plotPixel(_x0 + x, _y0 + y, _color)
        plotPixel(_x0 - x, _y0 + y, _color)
        plotPixel(_x0 + x, _y0 - y, _color)
        plotPixel(_x0 - x, _y0 - y, _color)
        plotPixel(_x0 + y, _y0 + x, _color)
        plotPixel(_x0 - y, _y0 + x, _color)
        plotPixel(_x0 + y, _y0 - x, _color)
        plotPixel(_x0 - y, _y0 - x, _color)
    The code works well for radi that are smaller, but as the circle expands to larger radi it begins to look more polygonish (8 sides).· I will have to read more about this.· I bet it has to deal with the simplifications and·the reflections.· For now though it will work to express the point of the 8-bit driver.
    Timothy D. Swieter
    www.tdswieter.com
    edited 2008-03-18 05:09
    Timothy,
    Would a generic sine/cosine algorithm work for drawing circles? or would that be too slow? You could cut it into quadrants so that the sine/cosine would only need to calculate for 1/4 of the circle and just translate the remaining 3/4 and that would speed it up a little bit.
    Beau Schwabe
    IC Layout Engineer
  • Gerry KeelyGerry Keely Posts: 75
    edited 2008-03-18 16:39
    The SSD1331 driver has built-in line(register 0x21) and rectangle(register0x22) drawing routines
    http://www.4dsystems.com.au/downloads/micro-OLED/uOLED-96-PROP/Docs/Pdf/SSD1331.pdf
    <!--EndFragment -->
    Regards
    Gerry
    edited 2008-03-18 21:02
    mpark said...
    OwenS said...
    Oops, yes. I never thought about that method of implementing it (I've been doing most of my graphics work on architectures with hardware divisors; In that case, division can be faster, depending on the speed of your divisor)
    edited 2008-03-18 23:58
    Thank you guys for the responses.
    Gerry - I realize the oled driver has built in drawing algorithms, but I am avoiding those. I created a display driver which clocks video memory into the OLED at 6ms per frame. I am not working on an 8-bit graphics driver to draw in the Propeller memory.
    I did figure out a circle routine from another post in the forum, I think it was Paul Sr. I also added sprite ability and text ability. Again it is just a collection of SPIN routines at this time, so it isn't fast, but in time I hope to transfer to ASM. I am cooking up a small demo now and will post in a day or so.
    Timothy D. Swieter
    www.tdswieter.com
    edited 2008-03-19 12:40
    I made a post in the Propeller forum regarding the uOLED-96-PROP display driver and SPIN graphics driver I am creating.· I didn't post the code yet, but soon I will.· For now there is demo program you can watch on YouTube or download via an EEPROM file.·
    http://forums.parallax.com/showthread.php?p=716659
    Timothy D. Swieter
    www.tdswieter.com
    edited 2008-03-22 11:54
    I posted the code in the object exchange for the 8-bit ASM and graphics driver. Check the reference post above for further details.
    Timothy D. Swieter
    www.tdswieter.com
  • pharseidpharseid Posts: 192
    edited 2008-04-09 21:16
    · I once used Bresenham's algorithm to draw polygons too. I used an array with 2 columns and as many rows as the vertical height of the screen. I would consider the points of the polygon 2 at a time and write the x coordinate calculated by the algorithm into one element of the array (the y coordinate implied by the position in the array). When the whole polygon had been processed, I would then render the array doing a line fill for each pair of coordinates in the array (for the max and min Y coordinates of that polygon).
    -phar
  • Lord SteveLord Steve Posts: 206
    In case anyone's interested.· Here's a SPIN Line drawer.· Works in all quadrants.· Works with byte-sized pixels.
    PUB Line(x0, y0, x1, y1, color) | pScreen, dx, dy, major, minor, majorStep, minorStep, error, errorAdjust, errorStep
      pScreen := @screen + y0*SCREEN_WIDTH + x0
      dx := x1 - x0
      dy := y1 - y0
      if ||dx => ||dy
        major := ||dx
        minor := ||dy
        majorStep := 1
        if dx < 0
          majorStep := -1
        minorStep := SCREEN_WIDTH
        if dy < 0
          minorStep := -SCREEN_WIDTH
      else
        major := ||dy
        minor := ||dx
        majorStep := SCREEN_WIDTH
        if dy < 0
          majorStep := -SCREEN_WIDTH
        minorStep := 1
        if dx < 0
          minorStep := -1
      error := major
      errorAdjust := major << 1
      errorStep := minor << 1
      repeat major + 1
        byte[noparse][[/noparse]pScreen] := color
        pScreen += majorStep
        error += errorStep
        if error => errorAdjust
          error -= errorAdjust
          pScreen += minorStep
