sharing value between methods
Any advice on how to share a value between two methods (which are running on separate cogs)?
When I press the button the LED turns on but it won't flash - my code is below.
Shmow
Shmow
'' File: Sharing Variable Content.spin
{{One method manipulates variable's value and another method
annunciates it to a LED on pin17 - only when a pushbutton (pin 23) is pressed}}
CON
_clkmode = xtal1 + pll16x
_xinfreq = 5_000_000
DAT
Value_Led byte 0
VAR
long stack[noparse][[/noparse]20]
byte LED_One
PUB Main
'with pushbutton pressed, second cog and method are started
'when button is released, second cog is stopped and P17 goes low
dira[noparse][[/noparse]17] := %1
repeat
if ina[noparse][[/noparse]23]
coginit(7, Second_Flash, @stack[noparse][[/noparse]10]) 'method starts in separate cog
Led_One := Value_Led
outa[noparse][[/noparse]17] := Led_One
else
cogstop(7)
outa[noparse][[/noparse]17] := 0
PUB Second_Flash
'value repeatedly toggles between one and zero at one second intervals
'then assigned to memory location
repeat
byte[noparse][[/noparse]@Value_Led] := 1
waitcnt(clkfreq + cnt)
byte[noparse][[/noparse]@Value_Led] := 0
It takes a while for COGINIT or COGNEW to finish. They both set up the other cog, but finish and go on to the next statement a long time before the other cog actually finishes loading and starts (over 100us). Your program loops back and does a COGINIT again long before the 2nd cog would finish loading starting the process over again. Even when the button is released, the new cog is STOPped before it could ever start running.
when the input 23 (pushbutton) goes high...
-the 8th cog is started
-which runs Second_Flash method - toggling a value between 1 and 0 every two seconds
-the Second_Flash method also assigns this changing value to a memory location (byte[noparse][[/noparse]@Value_Led])
-the Main method (running in the default and separate cog) reads the contents of this memory location
-and assigns this value to the output pin (17).
when the input 23 (pushbutton) goes low...
-the 8th cog stops
-the output pin (17) also goes low
How I've interpreted your reply: If I hold down the button then the 8th cog is re-initiated constantly,
or this cog is stopped before anything can happen (if I release the button too soon.)·
To test that idea, I edited out the code in the ELSE portion of that method but still no flashing output.
Looks like I haven't grasped the timing·of cogs yet.·
Perhaps you can steer me in the right direction.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 DAT Value_Led byte 0 'address of memory location that Second_Flash method writes to 'and Main method reads from VAR long stack[noparse][[/noparse]20] byte LED_One PUB Main 'with pushbutton pressed, second cog and method are started 'when button is released, second cog is stopped and P17 goes low dira[noparse][[/noparse]17] := %1 repeat if ina[noparse][[/noparse]23] 'pushbutton input true when pressed coginit(7, Second_Flash, @stack[noparse][[/noparse]10]) 'second flash method starts in separate cog Led_One := Value_Led 'value written in memory assigned to local variable outa[noparse][[/noparse]17] := Led_One 'output pin mirrors variable value else 'pushbutton input false when released cogstop(7) 'separate cog is stopped outa[noparse][[/noparse]17] := 0 'output pin goes low PUB Second_Flash 'value repeatedly toggles between one and zero at one second intervals 'then assigned to memory location repeat byte[noparse][[/noparse]@Value_Led] := 1 'high value of 1 sent to memory waitcnt(clkfreq + cnt) ' pause for 1 sec byte[noparse][[/noparse]@Value_Led] := 0 'low value of 1 sent to memory waitcnt(clkfreq + cnt) ' pause for 1 secRepeatedly re-initialising the cog doesn't give it time to do anything. A bit like dragging a runner back to the start line while the race is under way.
CON _clkmode = xtal1 + pll16x _xinfreq = 5_000_000 VAR long stack[noparse][[/noparse]20] byte Value_Led PUB Main 'with pushbutton pressed, second cog and method are started 'when button is released, second cog is stopped and P17 goes low dira[noparse][[/noparse]17] := %1 Value_Led := 0 repeat if ina[noparse][[/noparse]23] 'pushbutton input true when pressed coginit(7, Second_Flash, @stack[noparse][[/noparse]10]) 'second flash method starts in separate cog repeat until Value_Led 'wait until cog starts up outa[noparse][[/noparse]17] := Value_Led else 'pushbutton input false when released cogstop(7) 'separate cog is stopped outa[noparse][[/noparse]17] := 0 'output pin goes low Value_Led := 0 'reinitialize for next time PUB Second_Flash 'value repeatedly toggles between one and zero at one second intervals 'then assigned to memory location repeat Value_Led := 1 'high value of 1 sent to memory waitcnt(clkfreq + cnt) ' pause for 1 sec Value_Led := 0 'low value of 1 sent to memory waitcnt(clkfreq + cnt) ' pause for 1 secNote that the second cog doesn't need to use the byte notation to access the variable.
Anything in a VAR or DAT section is global to the object.
This still won't do what you say you want, but it will do what the original program
was written to do. You need to only start the blinking cog once, when the pushbutton
is initially depressed. If the button is still on and the cog is already started, you just
want to copy Value_Led to the output pin.
Normally with the Propeller, if you want a cog to do blinking like this, you give control
of the I/O pin over to that cog. The direction register bit in the cog is set to output
and the cog does the blinking. You could even dispense with the variable since the
input registers of all the other cogs give the actual output state of the I/O pin. You
wouldn't need to turn off the LED since, by stopping the blink cog, the direction
register of the blink cog would be cleared to zero making the I/O pin an input.
VAR byte cog long myStack[noparse][[/noparse]20] PUB start(pin,msOn,msOff) stop return cog := cognew(blink(pin,msOn,msOff),@myStack) + 1 PUB stop if cog cogstop(cog~ - 1) PRI blink(pin,msOn,msOff) dira[noparse][[/noparse]pin] := 1 repeat outa[noparse][[/noparse]pin] := 1 waitcnt((clkfreq/1000)*msOn + cnt) outa[noparse][[/noparse]pin] := 0 waitcnt((clkfreq/1000)*msOff) + cnt)-Phil
VAR long stack[noparse][[/noparse]20] byte Value_Led byte Button_Pushed PUB Main dira[noparse][[/noparse]17] := 1 Value_Led := 0 Button_Pushed = 0 repeat if ina[noparse][[/noparse]23] <> Button_Pushed Button_Pushed ^= 1 if Button_Pushed Cog_Number := cognew(Second_Flash, @stack) + 1 else if Cog_Number cogstop( Cog_Number~ - 1 ) Value_Led := 0 outa[noparse][[/noparse]17] := Value_Led PUB Second_Flash repeat Value_Led := 1 ' high value of 1 sent to memory waitcnt(clkfreq + cnt) ' pause for 1 sec Value_Led := 0 ' low value of 1 sent to memory waitcnt(clkfreq + cnt) ' pause for 1 secPost Edited (hippy) : 3/17/2008 11:51:55 AM GMT
