Best way to draw power from 14v AC?
I want to power a stamp and some associated logic circuitry off of a 14v AC line (model train application).
Would it be best to drop the voltage to ~ 7.5 by some rectifying diodes in series, then feed that into a cap and standard voltage regulator? Or is there a better way?
Edit: I have come across the TI PTN78000W:
focus.ti.com/docs/prod/folders/print/ptn78000w.html
Is that the kind of module you had in mind?
Post Edited (Professor Chaos) : 3/12/2008 6:03:56 AM GMT
http://www.mouser.com/Search/ProductDetail.aspx?qs=oc52yH%252bc6pXbMBQXD6wg3w%3d%3d
