(New trap in propeller assembly) Not a trap, Just a typo — Parallax Forums
stevenmess2004stevenmess2004 Posts: 1,102
edited 2008-03-15 08:55 in Propeller 1
If you do this
DAT
org 0
'...some code
aLabel
     MOV 0,0
anotherLabel
     MOV 0,0
org aLabel
:otherLabel
    MOV 0,0
    MOV 0,0
    MOV 0,0
    JMP #:otherLabel
The compiler complains that it can't find otherLabel at the JMP line. I presume that this is because anotherLabel breaks it up into a different section. Just something to watch out for if you are doing overlays.
Post Edited (stevenmess2004) : 3/15/2008 8:58:52 AM GMT
    edited 2008-03-15 07:27
    Steven,
    This seems to compile fine. And it looks fine, too. I'm using version 1.05.8.
    Chip Gracey
  • stevenmess2004stevenmess2004 Posts: 1,102
    edited 2008-03-15 07:59
    Sorry Chip,
    I tried to cut it down to something simple and didn't check it...
    Anyway, this file shows the problem. Right down near the bottom there is a line with the label :loop1 and a bit further down there is a JMP that calls it. If you remove the ':' it works.
    I'll try and see if I can find a smaller example or cut this down to the smallest thing that causes the error. I had to add the .txt to upload the file.
    Post Edited (stevenmess2004) : 3/15/2008 8:04:48 AM GMT
    edited 2008-03-15 08:42
    Oh, I found it!
    You meant to type "if_nz", but you typed "in_nz", which was interpreted as a non-local label:
    ······················· ADD···· loopC1,#1
    ······················· CMP···· loopC1,#12····· wz
    ······· in_nz·········· JMP···· #:loop1
    Chip Gracey
    Thanks for that Chip. Sorry to cause you the trouble. Next time I'll check more carefully before posting something.
    Edit: Hey Chip, for the propeller II can you add a feature to the compiler so that it knows what you meant to type and not what you actually typed? smile.gif
    Post Edited (stevenmess2004) : 3/15/2008 9:02:05 AM GMT
