"Ruggedized" PING))) sensor mounting?
Vern Graner
I'm working on a project that wil be placed in a children's museum. It makes use of PING))) sensors to detect hand positions to teach about sonar sound.
Since the ping sensors will be used by kids, I need to find a way to protect the sensors from kids poking their fingers into the transducers. I tried recessed mounting the ping behind a piece of acrylic with a grid of holes in front of it (kinda like a speaker grill) but that caused the sensor to mis-read (i.e. shows items very close to the sensor when there are none).
Anyway, I was hoping someone else had gone down this road and might have advice on how to mount the PING))) sensor in such as way that it
1) works and ranges properly and
2) is fairly well protected from kids fingers.
Any help appreciated!
Vern
Vern
Vern Graner CNE/CNA/SSE | "If the network is down, then you're Senior Systems Engineer | obviously incompetent so why are we Texas Information Services | paying you? Of course,if the network http://www.txis.com | is up, then we obviously don't need Austin Office 512 328-8947 | you, so why are we paying you?" ©VLG
Post Edited (Phil Pilgrim (PhiPi)) : 3/10/2008 9:16:08 PM GMT
The panel is supposed to light up concentric rings of LEDs in proportion to your hand's distance from the panel. I have the code working fine with the sensor sitting on the desk, but the moment I place the sensor behind the "grill", it's readings become all close to "zero distance" regardless of the distance of any object in front (i.e. hand position).
You think this might be caused by cross-talk from the Plexiglas?
Vern
Frankly, I'm stumped.
Good luck with the project, and I think the kids with enjoy it.
David
There are 10 types of people in this world,...
Those that understand binary numbers, and those that don't!!!
Post Edited (David H.) : 3/11/2008 8:06:56 PM GMT
I suppose I could try and make the tubes less resonant by coating the insides with cloth, or foam or some such, but I still end up with an opening I have to protect from curious fingers, so I'm back to some sort of grill or mask that again might interfere with the signal.
You spelled "destroy" wrong...
Vern
Post Edited (Vern) : 3/11/2008 10:15:11 PM GMT
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
Post Edited (Dgswaner) : 3/11/2008 10:12:28 PM GMT
DGSwaner
easier than a ping.
The exhibit is to demonstrate sound, both sonic and ultrasonic, hence the PING))) sensor. If I could use an IR ranger I could do it without making any opening in the front panel and that would really be ideal, but this is a display to demo sonar.
Vern
What are you trying right now? I'm curious about any progress you might be making to eliminate the errant echoes...
You can get a similar result using the softest PVC you can find cut to size so it fits around the transducers (not too tightly). Lining with any sound absorbent material will help w/echoes (i.e. thin felt). You suggested this, but don't fill the tubes, line them. You can get away with very long tube lengths (9"-18") -- given the small diameter of the transducers on the ping, and that kind of length, I would think kids won't be able to get fingers to Ping)))s. I think the only possible issue is that someone could put an object in (marble, pocket lint, boogers, etc). You would also try rolling very narrow cones (so that the aperature at the display end is wider than the transducer end) out of a think backing lined with felt (perhaps very very thin sintra with very thin felt cemented on before cutting).
The other thing to try is to hit a professional audio supply house (if you have one in your area) -- you can get "aurally transparent" grilles (i.e. foam, cloth, weaves, etc.) that may do the trick -- and probably for not much $$. I wouldn't spend time experimenting with off the shelf cloth/foams/etc. -- if the material is not designed to be aurally transparent, then chances are it won't be, esp. at the high frequencies of sonar.
Very cool exhibit. The kids will love it. Have you all thought about different kinds of gloves for kids to experiment with? Put in a bin near the exhibit? For example, a soft fuzzy glove (like a care waxing glove) will probably reflect almost no sonar. A glove with a hard plastic disc on the palm will reflect really well. An ungloved hand will reflect pretty well, but not always.
These fan grills are available in 40mm, 60mm and 80mm sizes so I should be able to find one that would be able to cover the PING sensor without being so large as to cover the rest of the panel. The hope is that the round surfaces of the wire used to make the grill will better pass the sound without fear of flat, parallel surfaces causing resonations.
Also, I'm hoping the wider bar spacing will stopping kids fingers from reaching the more fragile metal screen at the front of the ping sensor.
These fan grills are cheap and easily found so I will be testing the theories expressed here this weekend. Wish me luck!
Vern
I can see you're thinking along the same lines.
I did try some cloth over the top of the sensor and the ping sensor worked fine though it. I just used a simple household hand towel. The problem is that any cloth would get shredded pretty quick. Also, the materials all have to be "cleanable" and they use a spray disinfectant / glass cleaner to make it sanitary (as much as possible). I don't think they would like to have to remove little cloth pieces and wash them daily.
This is a very cool idea... Maybe have small pieces of material on lanyards that can be held up in front on the display.. A piece of fuzzy fake fur on disk... a piece of hard plastic.. a piece of opaque plastic and a piece of transparent plastic. Hmm this is an interesting idea. Thanks!
Vern
This is such a cool exhibit idea -- keep everyone posted once you've got it up and running.
Vern
For those of you that have been following this thread, we tried the silver fan grills and they are NOT transparent to sonar. as a matter of fact, they work fine as reflectors! You can hold them in front of the sonar unit and it "sees" the grill as a solid surface! [noparse]:sigh:[/noparse] I'm still looking for a solution. when I find one I'll let you guys know.
Vern
Post Edited (Vern) : 3/17/2008 6:13:31 PM GMT
Yo, Parallax folks -- what is the wire mesh on the Ping))) covers and where did you get it?
the Mesh from it and using that?
http://www.hobbyengineering.com/H4095.html
Searider
Searider
Looks like it might be possible to replace the transducers on the PING with some of these solid aluminum ones! Hmm.. Of course warranty void blah blah..
Heres the two PDF documents with the specs in case anyone wants to have a look:
Part # 400ET R180 sensor module from Hobby Engineering
Part # CUR17G1A-40 used on PING))) sensor from Parallax
Vern
Impact has caused the metal mesh to recede into the tube when pressed with a finger or hit. I've also seen holes torn in the mesh by people wearing rings while playing the instrument.
Its looking like the aluminum transducers might be the ticket, but I'll have to order them to find out (and sacrifice one ping sensor to test). More delays! :[noparse]:sigh:[/noparse]:
Vern
Post Edited (Vern) : 3/18/2008 11:13:49 PM GMT
The new H2O PING sensor
Cool!
Vern
