Could some look at this FOR NEXT Routine and tell me if this the right way to d — Parallax Forums
sam_sam_samsam_sam_sam Posts: 2,286
edited 2008-03-10 04:55 in General Discussion
This seem to work the way that i want it to work but is this the right way to this
run:
DO··················
HIGH led·············
LOW chg··············
PAUSE dly1
'charge·············
LOW led··············
HIGH chg
PAUSE dly1
'input
LOW led
INPUT chg
PAUSE dly2············
DEBUG CR, DEC ? chg
GOSUB Get_Time
·DEBUG HOME, HEX2 mins, ":", HEX2 secs, CR
·IF secs = $59 THEN
PAUSE 1000
·ENDIF
IF chg = 0 THEN········
· PAUSE dly3
ELSE
· IF chg = 1 THEN········ ······················· '·I want to run so many times to see if it still true if so then do something
· FOR idx = 1 TO 300···························· ·' This seem to work but is this the right way to do this
· DEBUG DEC5 ? idx , DEC5 ? leaps
From here down i want to run so many time if this statement stays true· IF leaps = 300 AND chg = 1 THEN EXIT·····
____________________________________________________________________________________________________
· HIGH led·············
PAUSE dly1
'charge··············
HIGH chg
PAUSE dly1
'input
LOW led
INPUT chg
DEBUG CR, DEC ? chg
leaps = leaps + 1
NEXT
·idx = idx + 1
ENDIF
· ENDIF
LOOP
DO
HIGH 14
PAUSE 100
LOW 14
PAUSE 100
LOOP
··Thanks for any·idea.gif·that you may have and all of your time finding them
Sam
    edited 2008-03-10 03:50
    This is too complicated for such a general question. Please simplify your posting or ask a more specific question.
    Without a very specific question, it's impossible to tell you if this is a better solution than some other.
    edited 2008-03-10 04:02
    mike
    thank you for your reply
    The rountine that i have here i only want to do something if the statement stay true for so long
    I want to run through this routine 300 time to see if it stays true
    ·DO··················
    PAUSE dly1
    HIGH chg
    PAUSE dly1
    'input
    LOW led
    INPUT chg
    DEBUG CR, DEC ? chg
    · PAUSE dly3
    leaps = leaps + 1
    LOOP
    Sam
    edited 2008-03-10 04:18
    Sam -
    Look at the PBASIC Help file for LOOP UNTIL.
    Bruce Bates
    Programming can't be all that difficult, it's nothing but 1's and 0's
    edited 2008-03-10 04:47
    Bruce Bates
    Thanks for you reply
    ·This is what i try ed first was·LOOP UNTIL but as soon as· the statement was true it jump to the next stament which is not what i am wanting
    What i want is to loop so many time to see if it stay true then jump to the next statement
    Sam
    You can use the LOOP UNTIL statement, but you can also use the FOR / NEXT statement like:
    FOR i = 1 to 300
       IF NOT condition THEN EXIT ' This will cause the FOR / NEXT loop to quit early
    NEXT
