Could some look at this FOR NEXT Routine and tell me if this the right way to d
This seem to work the way that i want it to work but is this the right way to this
run:
DO··················
HIGH led·············
LOW chg··············
PAUSE dly1
'charge·············
LOW led··············
HIGH chg
PAUSE dly1
'input
LOW led
INPUT chg
PAUSE dly2············
DEBUG CR, DEC ? chg
GOSUB Get_Time
·DEBUG HOME, HEX2 mins, ":", HEX2 secs, CR
·IF secs = $59 THEN
PAUSE 1000
·ENDIF
IF chg = 0 THEN········
· PAUSE dly3
ELSE
· IF chg = 1 THEN········ ······················· '·I want to run so many times to see if it still true if so then do something
· FOR idx = 1 TO 300···························· ·' This seem to work but is this the right way to do this
· DEBUG DEC5 ? idx , DEC5 ? leaps
From here down i want to run so many time if this statement stays true· IF leaps = 300 AND chg = 1 THEN EXIT·····
____________________________________________________________________________________________________
· HIGH led·············
PAUSE dly1
'charge··············
HIGH chg
PAUSE dly1
'input
LOW led
INPUT chg
DEBUG CR, DEC ? chg
leaps = leaps + 1
NEXT
·idx = idx + 1
ENDIF
· ENDIF
LOOP
DO
HIGH 14
PAUSE 100
LOW 14
PAUSE 100
LOOP
··Thanks for any·
·that you may have and all of your time finding them
Sam
run:
PAUSE dly1
HIGH chg
PAUSE dly1
'input
LOW led
INPUT chg
DEBUG CR, DEC ? chg
GOSUB Get_Time
·IF secs = $59 THEN
PAUSE 1000
·ENDIF
· PAUSE dly3
ELSE
PAUSE dly1
HIGH chg
PAUSE dly1
'input
LOW led
INPUT chg
DEBUG CR, DEC ? chg
leaps = leaps + 1
NEXT
·idx = idx + 1
ENDIF
· ENDIF
LOOP
DO
HIGH 14
PAUSE 100
LOW 14
PAUSE 100
LOOP
··Thanks for any·
·that you may have and all of your time finding them·
Sam
Without a very specific question, it's impossible to tell you if this is a better solution than some other.
thank you for your reply
The rountine that i have here i only want to do something if the statement stay true for so long
I want to run through this routine 300 time to see if it stays true
·DO··················
PAUSE dly1
HIGH chg
PAUSE dly1
'input
LOW led
INPUT chg
DEBUG CR, DEC ? chg
· PAUSE dly3
leaps = leaps + 1
LOOP
··Thanks for any·
Sam
Look at the PBASIC Help file for LOOP UNTIL.
Bruce Bates
Programming can't be all that difficult, it's nothing but 1's and 0's
Thanks for you reply
·This is what i try ed first was·LOOP UNTIL but as soon as· the statement was true it jump to the next stament which is not what i am wanting
What i want is to loop so many time to see if it stay true then jump to the next statement
··Thanks for any·
Sam
