splitting up an Array[s]
I am trying to take a number from 0 - 100 and fill an array with it. i.e
How do i write a loop using a bit shif?
help me please...
long stringdata <------array long X <------varable Pub Start X = 100 loop: stringdata[noparse][[/noparse]0] := 1 stringdata := 0 stringdata := 0 end loop
help me please...
2) There are no labels in Spin. Read the description of the REPEAT statement. This combines the FOR / NEXT loop and the DO / LOOP statements in Parallax Basic.
I want to do a repeat so that the variable X is broke up into an array named data
x = 100 ||| data [noparse][[/noparse] 0 ] <-||| data [noparse][[/noparse] 1 ] <--|| data [noparse][[/noparse] 2 ] <---|so that when the "repeat until" is done I will have this --> data [noparse][[/noparse] 0 ] = 1 and data [noparse][[/noparse] 1 ] = 0 and data [noparse][[/noparse] 2 ] = 0
Post Edited (grasshopper) : 3/7/2008 9:54:12 PM GMT
Paul Baker
Post Edited (Paul Baker (Parallax)) : 3/7/2008 11:12:34 PM GMT
All i want to do is put a three digit number like 100 into an array so that i can display this on my LCD screen. Why is it so hard to program the propeller. I figured i could do this but i have no such luck: Thank god you are all here...
con esc = $1B 'Escape code cr = $0D 'Carriage Return code lf = $0A 'Line Feed code eos = $FF 'End of string code eog = $FF 'End of graphics code space = $20 'Space character code max_duty = 100 pwm1pin = 7 VAR long stringdata[noparse][[/noparse] 7 ] long x long number long stringdata1[noparse][[/noparse] 4 ] obj LCD : "LCDDEMO2" pwm1 : "pwmasm" pub main repeat DISPLAY PULS_STIRR waitcnt(100_000_000 + cnt) PUB DISPLAY | Y LCD.init 'Initialize the display lcd.clS RETURN PUB PULS_STIRR | Y pwm1.start(pwm1pin) pwm1.SetPeriod(1_000_000) 'high period will allow for a slow motor repeat x from max_duty to 100 'linearly advance parameter from 0 to 100 pwm1.SetDuty(x) waitcnt(1_000_000 + cnt) 'wait a little while before next update repeat y from 0 to 3 stringdata1[noparse][[/noparse] Y ] := (x ~> Y - 1) ' pack the characters into a long lcd.cls lcd.writeout(stringdata1[noparse][[/noparse] 0 ]) lcd.writeout(stringdata1[noparse][[/noparse] 1 ]) lcd.writeout(stringdata1[noparse][[/noparse] 2 ]) returnPUB dec(value) | i '' Print a decimal number if value < 0 -value out("-") i := 1_000_000_000 repeat 10 if value => i out(value / i + "0") value //= i result~~ elseif result or i == 1 out("0") i /= 10but instead of using the out method, you would assign it to your·data array.
Paul Baker
Plenty of scope to optimise the code there, but shown longhand for clarity.
If you want ascii characters in yourArray[noparse]/noparse rather than numbers ...
Post Edited (hippy) : 3/8/2008 2:48:32 PM GMT
I figured it out using both of your examples .
