DS2438 - Object needed
Hi everyone,
Would anyone be interested in writing an object for the DS2438 Smart Battery Monitor?
After reading the datasheet I have come to the conclusion that this would be great to measure the output of the 5.0 and 3.3 volt regulators and the current being drawn from them.
Here is the datasheet if anyone is interested - datasheets.maxim-ic.com/en/ds/DS2438.pdf.
Thank you
Check out my robot using the propeller RECONAUTOR
If you like my avatar then check this out Propeller Domed Sticker
Thank you
However if anyone has any advice/comments please post.
Thank you
This will work great for a starting point.
Thank you
It's a cheap-and-cheerful way to create a simple protection scheme ( does the code match what the software expects ) and the software can be written so it writes the code to Eeprom the first time it runs so no need to alter the downloaded code for every released product.
It's fairly easy to crack though but the serial number could be used in more advanced ways.
