Single cog Propeller?
Musings:
I think the propeller is interesting but i wish they would have made a single cog chip, running at 100Mhz with 4k words of memory. The cog has a nice
instruction set architecture it just needs to address more than 512 word of memory. Increasing the instruction length to reach 4k words would be adequate for these applications. The hub concept is very good but it takes expensive,in die area, hardware to make it as fast as the basic cog.
Any commnets?
cheers,
rcih
<subject line added by moderator>
Post Edited By Moderator (Paul Baker (Parallax)) : 3/7/2008 7:00:02 PM GMT
Any commnets?
cheers,
rcih
No, I am not kidding. A COG is quite similar to an ARM, and you will have MUCH more expandibility that way...
It will not be more expensive....
Take it a step further and a Cog can execute PASM from I2C Eeprom or SD Card. Using other Cogs to do caching could make that quite efficient in many cases.
Such a chip can still do TV or VGA (_Text) output, has 4 32Bit Counters, needs no interrupt system ....
I would prefere such a chip to every other Low cost processer. And I'm shure it would dramatically increase the propagation of the propeller chip.
Andy
www.mikronauts.com - a new blog about microcontrollers
Yes it would destroy the market, and also Parralax, as the losses would be enormous, don't you think?
Yes everyone wants things cheaper, but you also have to be realistic.
A sngle or 2COG prop is too limited if you ask me...
A 4-COG, with 16 I/O should fit in a 24pin DIP, though.
Of course, the HUB access needs to be the same as on the 8-COG version so that timing is consistent.
but the chance of getting anything like this?
Very, very close to ZERO.
Yes, Parallax wants to give us what the customers want, but they also need to make money on it, and having to stock more versions of the same chip, which sells to the same markets isn't a good idea.
And it probably wouldn't be much cheaper, either.
Yes, they can reuse most of the design from the original, but it'd need a new round of testing, and the production costs will be about the same anyway.
Besides, Chip is busy designing the next generation Propeller chip, and I'd much rather have him work on that...
Don't visit my new website...
Graham
And why is it, with a chip this capable, are we constantly, CONSTANTLY, trying to cram a Battleship, into a mooring made for a dingy when we have the elbow room for a battleship?! I must be missing something..
Basically what I'm saying here is that the prop is a great chip & being an American, bigger is better!! Bring on the Prop gen II!! They did a VERY good job with the chip, so what if you have a few COG's taking a nap...
E3 = Thought
http://folding.stanford.edu/·- Donating some CPU/GPU downtime just might lead to a cure for cancer! My team stats.
