Prototyping board FAQ, other FAQs
Might I suggest that a faq/guideline sticky be put together for those of us wanting to take our STAMP off of the BOE and go to a prototype board. I know there are the schematics for the carrier board and super carrier board, but it would be nice to have some official guidelines that specify the types/size of caps to use on regulators, when to use an external regulator and when to use the on-board, when to add extra caps, when to use a diode on the regulator, how/if to terminate un-used pins, etc, etc, etc... I know a lot of it would depend on the circuit being designed but I think just a basic guide for getting off the BOE and onto a proto-board with what the minimum requirements are and what's recommended... would be really helpful to those of us who are new to not just the STAMP but electronics in general.
As a side note I also think some other stickies ought to be made for a lot of the commonly asked questions here, such as trouble shooting STAMP<->PC connections, etc. ... as well as just a basic "check here first, try this first, then ask" guide for the forums. Just some ideas.
Post Edited (Jed) : 3/5/2008 1:20:17 AM GMT
Its hard to find some of that info as a newbie.
Your posts bring to mind several thoughts... Jed, you seem to be asking Parallax to provide a condensed version of a course leading to a degree in electronics. I'm not trying to belittle your efforts at all, but micro-controllers encompass a number of complex fields. Parallax would be hard-put to cover every potential situation, and there are SO many trade-offs in electronics... Actually, Parallax does supply recommended values for the part used. Just look at the schematic. (caveat here; wattages for resistors and working voltages for capacitors not shown, probably because they aren't critical)
A very good alternative to the BOE is the Super Carrier (p/27130). It doesn't have servo sockets, but that is easily remedied, and you can mount your own experimenter-prot board in the prototyping area... I couldn't make my own prototyping board for much less than 19.95 after purchasing all the parts.
As for physical size of parts, there is so much variation, depending on the individual's needs, availability, etc. and on and on. If your goal is to improve on the BOE, then you need to do some research. If it's a cost issue, buy the Super Carrier
But remember, Parallax is in business to sell the various parts of the system that it developed, and is remarkedly free with information compared to some companies.
All of that said, please don't think that i'm putting you down, but please bear in mind that so much depends on specific applications, as Ugha can wel attest.
There is merit in your final suggestion concerning a sticky for troubleshooting, etc. In fact, there may even be one; I know that there is a huge FAQ that I haven't read... By there way there is another forum for suggesting changes, improvements, etc.. You might want to post there.
Ugha, have you found that it is really hard to find information, or rather that you tend to find more than you thought you wanted?
Keep on truckin' guys, and you'll get there
Terry
It's more like there are huge pieces of information missing. Pieces that someone seeking the "next step" of learning have
a hard time filling in.
Basiclly, there's not enough information out there for the layman.
Chris Savage
Parallax Tech Support
The best advice that I can give is Google, google, google. And read, read, read. The information is out there, but aside from signing up for a class at your local Junior College you will have to dig for it.
A good place to start is the follwing site: http://www.play-hookey.com/dc_theory/
Read and think about every single highlighted word until you understand it... If you skip any you WILL end up having to go back and revisit that part (there or on another web site) at some later date. By the way, AC circuit theory is just DC circuit theory with reactance added (now there is an over-simplification for you!)
Terry
