Uv radiation monitor device using bs2-ic
Hello everyone...I'm new to this forum and also new to the exciting world of parallax
. I recently purchased the Board of education(w/BS2-IC) usb with parts kit so that I could work on my·senior year·project...which I·will tell you about later.·So far·things have been going smoothly but I have got stuck on a few aspects of my project and could definitely use some much needed advice.So here goes the description of the project:
I am working on a UV(ultraviolet) solar radiation monitor that would detect uv radiation energy from the sun and then give a recommended time of exposure to that radiation. Now obviously this would involve a uv sensor or photodiode that would o/p a parameter such as variable(analog)·voltage, current or resistance(very rare).
I have been looking on the web for some photodiodes and uv sensors that would interface with the board of education platform and found one (OKI - ML8511). But unfortunately this one is really tiny and is primarily used in cell phones and ultraportables.
So is there anybody who has worked on a similar project before and can give me a recommendation on a UV photodiode or sensor that I can interface with this platform. And also what other obstacles should I be expecting in the near future
..Thank you so much!
http://www.oki.com/en/press/2007/z07004e-2.html
http://www2.okisemi.com/site/productscatalog/MEMS/UVSensors.html
There may be reason to separate out UVA and UVB for better handle on exposure. The signal is likely to be small, in the range of nanoamps. The full sun earth surface UVA is I recall around 5 W/m^2, and around 1 watt/m2 for UVB.
On the other hand, you might find a UV emitting LED and use it in reverse as a photodiode, as a quick and dirty. Assume a proportion will be UVA and UVB.
Tracy Allen
www.emesystems.com
On their website, TAOS lists UV sensing as an app for their light-to-frequency sensors. You might give them a call to see what they had in mind.
One of them is the ERYCA UV Index Si-C sensor/photodiode whose spectral response nearly matches the erythema curve
Checkout the datasheet at http://www.sglux.de/fileadmin/datasheets/ERYCA.pdf
The other one(s) is similar to this and also is used in UV Index measurement...
http://www.ifw-bauelemente.de/www/ifw_be/english/photodioden/?abteilung=10B8F42D3EF
This one is more comprehensive and shows a variety of sensors that fall under this criteria.
Also, one more thing...since my major requirement is a sensor that would easily integrate with the BoE platform...any good UVA photodiode that works with parallax products should also do the job fine . I'm not looking to spend hundreds of $$ on this project..still a student [noparse]:)[/noparse]
P.S. - Should the ADC0831 recommended by parallax do the job of converting to bits.....I was thinking of using a lookup table stored in the eeprom of BS2 IC to compare values from [noparse][[/noparse] UVA->ADC <-> Lookup Table ] of the UV Index.
