help with a bit of imbedded java
please could give me hand, i've sketched this together, it eventually ends up going into a op amp, the idea is, to have a endless loop of ints. as a string, that then launches 2 "make voltages" into the amp , the superhetrodine principle takes care of the rest, giving me 4 or 1 frequency(s) accordingly , amplified i,m hoping it will be a good signal jammer, i,ve used a frequency counter and ossiloscope to get accurate frequency response, (a sizable list!). if you want to expand it further it would be nice to have a random seed select the freqs, but memory is low at that point...... please, could you get the thing to turn over, to the point of the debugger, as a working program...... may the force be with you, thankyou
program attached
so there is a single while (true) loop in your main(), updating two DACs.
regards peter
