indexed Propeller Manual
Quite a while ago, Someone had edited the Propeller Manual PDF and added an index to help quickly locate information within the manual. I can't seem to locate it now. Any one know of it's location?
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
Brian
http://forums.parallax.com/showthread.php?p=677274
i took the parallax google searchfunction
search.parallax.com/search?q=+%2B%22f%3D25%22&btnG=Google+Search&client=parallax&lr=&num=100&output=xml_no_dtd&site=parallax&ie=&oe=&sort=&proxystylesheet=parallax
and here it is
+f25 focuses on the propeller-forum
then add your keywords
or do you prefer a direct downloadlink ?
www.rayslogic.com/propeller/Propeller%20Manual%20v1.01bmarked.pdf
(just as ultra-specific keywords to find it easy again
parallaxpropellermanualindexed indexedmanual indexedpropellermanual bookmarkedpropellermanual bookmarkedmanual
downloadlinkparallaxpropellermanualindexed downloadlinkindexedmanual downloadlinkindexedpropellermanual downloadlinkbookmarkedpropellermanual downloadlinkbookmarkedmanual
downloadparallaxpropellermanualindexed downloadindexedmanual downloadindexedpropellermanual downloadbookmarkedpropellermanual downloadbookmarkedmanual
regards
Stefan
Post Edited (StefanL38) : 3/2/2008 10:30:23 PM GMT
Odd, when I searched for "indexed Propeller Manual" at search.parallax.com It wasn't able to find it.
Thank you, I've got it saved on my hard drive now.
Maybe pointing out it's existence will help others that didn't see it the first time. IMHO this should be put in a sticky or maybe Parallax should replace the manual that the Propeller Tool displays with this version?
I was getting by only miserably without it, which is why I took the time to create the bookmarks!
It's also a total mystery to me that http://www.rayslogic.com/propeller/propeller.htm is nowhere in the stickies.
