PINK and Dynamic DNS
Tumbler
Hi,
I asked this question yesterday to in another topic, but nobody answerd my question, so i asked it in a new topic.
I have a PINK module and a dynamic dns account at no-ip.com
I setup my router properly, forwarding ip and portnumbers etc...
When i open the website i get an empty webpage, i think pink's webserver is listening to port 80
The problem is my provider (telenet): telenet blocks all ports below 1024
Can i setup the pink webserver so it's listening to a higher portnumber?
Have you used the id utility that came with the PINK?
You should be able to put the PINK on the router and enable port 80 in the router setup process. Port 80 must be doable because I assume you can get on the internet with your computer, right?
Cheers,
Tom Sisk
http://www.siskconsult.com
- Rick
It wouldn’t make much sense to block everything below port 80. All web page traffic happens by default on port 80. In any event you should be logging into the address of your router and it will translate to the internal/private address on the network. I have found some routers require you to set static IP addresses on the local network for port forwarding. For example, my IP address at my router may be 205.232.34.1 (not really, but for demonstration purposes) and internally the PINK might be on 192.168.20.20. In the Router I would enable port forwarding for port 80 through to the PINK Module IP address. On the web I would go to 205.232.34.1. I hope this helps. Take care.
Chris Savage
Parallax Tech Support
I have a webserver too at my laptop. When i will make it public i have to setup another portnumber, otherwise it isn't possible to connect to. Sounds strange, but we have to do with it here
But is it possible via firmware to setup another portnumber?
Chris Savage
the site below will test all of the first 1024 ports for lets see what you get using this tool
https://www.grc.com/x/ne.dll?bh0bkyd2
Many ISPs now block incoming traffic to this port before it reaches their customers. This is done for several reasons: The prevalence of malicious port 80 Trojans renders outside access to this port dangerous. Many Windows users are inadvertently running or have not patched and are not maintaining copies of Microsoft's web servers. As we know, active scanning by self-propagating worms is constantly attempting to locate and infect such servers. Additionally, the terms of service of many ISPs forbids end-users to offer web services to the Internet. Blocking incoming traffic to port 80 can be an enforcement of ISP policies as well as a significant boon to end-user security.
http://www.grc.com/port_80.htm
Does that help?
Bad spellers of the world untie!
below is where I save all video's sent to me In emails
http://gaminde.net/Jokes/Movies/
Your system has achieved a perfect "TruStealth" rating. Not a single packet — solicited or otherwise — was received from your system as a result of our security probing tests. Your system ignored and refused to reply to repeated Pings (ICMP Echo Requests). From the standpoint of the passing probes of any hacker, this machine does not exist on the Internet. Some questionable personal security systems expose their users by attempting to "counter-probe the prober", thus revealing themselves. But your system wisely remained silent in every way. Very nice.
So, there is no other solution about this problem?
I have the same problem when i try to·put my apache webserver online. Apache runs under port 9100 here. Otherwise nobody can see my website (local)
Chris, what about the firmware? Is is possible?
No additional changes are planned to the firmware at this time. If we keep changing the firmware every time an ISP restricts use of a feature we will never have the firmware completed. As it was, the recent changes caused a lot of PINK Modules to be sent in for updates. Imaging doing this every month. There has got to be a work around. If my ISP blocked any traffic on my system I would seriously consider going with someone else. Blocking traffic is the job of the firewall in my router as well as my Anti-Virus software and updates. As it is my ISP recently started changing all mail access to SSL, which means that authentication is useless on the PINK Module. I am in the process of fighting this now.
Chris Savage
"No additional changes are planned to the firmware at this time. If we keep changing the firmware every time an ISP restricts use of a feature we will never have the firmware completed."
this may become true for more and more ISP's
So that's it, no remote control for me.
Well, what a waste, such a lot of money.
Post Edited By Moderator (Chris Savage (Parallax)) : 2/29/2008 6:34:17 PM GMT
What kind of router do you have name model and type of service dsl dialup
http://portforward.com/english/applications/port_forwarding/HTTP/HTTPindex.htm
- Rick
I have a few questions
1. wouldn't tcp ip be more important than a udp port setting
2. If Im running a server and serving webpages how would I use the Pink on port 80
Chris Savage
I give up now, thx all that helped me.
@Gaminde: What kind of router do you have name model and type of service dsl dialup:
·its a SMC2804WBR
·and type:
Luc
Post Edited (Tumbler) : 3/1/2008 6:50:32 AM GMT
- Stephen
I have the first hardware revision of the SMC2804WBR and it has a virtual server option that supports WAN to LAN port mapping. Try the following steps to see if it will work:
Your PINK must be configured either with DHCP or static ip. If you are using static ip, then make sure you have the correct subnet mask and gateway set. If it isn't correct, then your PINK won't know how to route packets outside of your network.
To test, you will have to use an external connection. You cannot use the same internet connection as your PINK for testing because a large portion of SMC's consumer routers do not support loopback. This means you cannot connect from to your external ip from your home. This is a huge flaw in SMC's firmware, which is why I no longer use any of their products. I have tried contacting them about numerous security issues in their NAT implementation, but they always tell me to reset my router or something like that.
Harrison
I have version V1.00.020.2005
i think it's the newest version (couldn't find a newer one)
At smc.com i couldn't find my router anymore, i think it's not supported anymore.
but when i go to the virtual server settings i only have a 'service port' field where·i can change the port number, and i can't find a private and public port field
Luc
This appears to be a unique problem in that I have never heard of anyone unable to host a web server from their internet connection. I’m sure there probably are a few that, for some reason restrict it, but there are other ways around that. A good router should be able to redirect traffic from one port to another. I know two of the three I have owned had this capability. I’m sorry to hear that you cannot get it to work. When a router is involved you cannot directly access the PINK anyway. A router inherently acts as a firewall in that it translates the IP Addresses between the internet and you local network. Therefore you cannot access the PINK on any system with a router without first setting it up in the port forwarding or using the DMZ. Note that using the DMZ also opens up the TELNET port making it easy to eavesdrop on traffic between the PINK and the BASIC Stamp.
Chris Savage
Plz read this article at grc.com
grtz
Luc
