Pink Bugs or is it just my old software
issue #1 ftping with WS_FTP V5.08 it's about 7 years old. but it still rocks!
I can't delete a folder unless I rename it first. once I rename a folder I can erase any folder. I'm not sure what happens, but at some point, especially if I log out I have to rename a folder again to delete it. I can delete files just fine.
Issue #2 Semi related. using Dreamweaver MX2004
when I look at the remote server (ftp) I can only see the folders no files in the root, I can't delete, rename or do anything other than see the folders in the root of the PINK.
I can FTP files to the pink including new directories, I just can't view them.
is anyone else having these issues? is there a setting I can change to fix this?
I'm using WS-ftp because I can't use Dreamweaver to manage the files on the PINK.
the FTP protocol is older than dirt so I wouldn't think an older program would be an issue.
Any thoughts?
A complex design is the sign of an inferior designer. - Jamie Hyneman, Myth Buster
Any thoughts?
I had the same with my pink, i also wasn't able to delete folders on the pink module, after renaming the folder, i could delete the folder.
Kurt Belgium
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
